460 Power
Old Jan 30, 2026 | 06:47 PM
79F150400M's Avatar
79F150400M
460 Power
Nothing better than a big block 460 sitting between the frame rails! Just playing in the shop today. Re-fabbing some braketry that was sub par.
Old Jan 30, 2026 | 11:00 PM
Greaser007's Avatar
Greaser007
I do like my 385 series 429, except the fuddy duddy power-steering pump bracketry.
I just did attempt to shim the bracket for the "V" groove belt system to bring the pump pulley into alignment with the crank pulley.
No joy yet, and I am convinced, I'm gonna have to remove and modify, as I've concluded it is Tweaked. Tightening makes it worse.
Good luck on the brackets you are working on.
What are the brackets for ?
Old Jan 30, 2026 | 11:26 PM
79F150400M's Avatar
79F150400M
The smaller one is for the FPR. I made one a few years ago but it was flimsy as I didn't use thick enough metal so I solved that issue. The other one is for the proportioning valve that's suppose to be attached to the top of the steering box. It wasn't an issue but I thought it would look a little better if it wasn't just floating out in space with no support. As a former aircraft mechanic....I like things buttoned up. I might be a little OCD. LOL
Old Jan 31, 2026 | 04:15 PM
79F150400M's Avatar
79F150400M
Proportioning valve just hanging out. I fabbed up a bracket to secure it. Just need to procure some bolts long enough to do the job. ACE hardware here I come.
There was a plastic bodied fuel filter down there. Don't want any potential fire hazards so it's gone.
Old Jan 31, 2026 | 04:19 PM
79F150400M's Avatar
79F150400M
Quick pic of my driveway. Hard to believe that millions of folks across the U.S are in the deep freeze. Youd never know it here. Its not sunny ..but it is 52 degrees.
Quick pic of my driveway. Hard to believe that millions of folks across the U.S are in the deep freeze. You'd never know it here. It's not sunny ..but it is 52 degrees On our way to breaking a record...the weather people say it's going to top out at 58.😎😎 Kinda crazy for January.
Old Feb 1, 2026 | 12:39 PM
tbear853's Avatar
tbear853
Just a bracket for FPR when I use an Edelbrock carb. The funny (odd) offset was just to use a handy scrap to clear a large vac fitting. I use longer front studs, regular nuts hold carb on, then set the bracket on, use two more nuts. !" wide x 1/8" steel, maybe 3/16"?
On the Holley, I mount similarly using two passenger side studs instead, FPR over pass valve cover. Metal fuel filter.
Sturdy, steady mounts.
Old Feb 1, 2026 | 12:55 PM
79F150400M's Avatar
79F150400M
Looks nice Tbear! I need to get a pic of my new bracket for the FPR...
Old Feb 1, 2026 | 04:45 PM
Rubiranch's Avatar
Rubiranch
I wish my truck had a 460.
Old Feb 1, 2026 | 05:11 PM
79F150400M's Avatar
79F150400M
You have that really cool Merc 410!
Old Feb 1, 2026 | 06:42 PM
Rubiranch's Avatar
Rubiranch
Thank you, but its not a460.
Old Feb 1, 2026 | 08:36 PM
SlikWillie's Avatar
SlikWillie
Are you going to change your handle to 79F150460 now? I will be building a very mild 429 to go in my '75 Highboy. I can't wait to drive it, but I'm going to take my time building it.
Old Feb 1, 2026 | 08:45 PM
79F150400M's Avatar
79F150400M
I've had some thoughts on changing my handle as I m aware it's not accurate but haven't come up with anything that I like. I no longer have the 79.
Old Feb 2, 2026 | 09:21 AM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
Man I love some ford big block.
djc1481
Mar 29, 2019 12:02 PM
F460bigbore
20
Aug 12, 2018 09:06 AM
jbas
Jan 29, 2018 10:11 PM
Jason Lewis
Feb 27, 2009 07:19 AM
