My Dura Spark II move
OEM location was out of the way in a corner, mounted on a vertical wall with three rusty self drilling sheet metal screws. OEM one lasted into May 2016 when it died. I got it home after cooling it off a few times. I replaced it then with a long carried spare which had leaked its potting into a box while stored behind the seat. It still worked, but leaked a little on the fender and was discarded soon and replaced by my current one, which has not leaked since May 2016.
I had considered moving it to inside the cab, but decided to just "Turn it open side up so it doesn't leak it's potting and maybe cool it.". I used a 1/8" thick piece of aluminum, 8" x6-1/2" and some 1/4-20 nut-serts to mount further forward on the inner fender. I extended my truck side plugs about 11", using 16 ga. wires, spliced, soldered, shrink wrapped, covered. I found that my current DS-II, my good spare NIB, and the OEM one I kept, all had the mount holes already tapped 1/4-20 threads so I used them to mount it under the plate.
I thought about just remounting it but leaving it way back beside the hinge, but was not so easy a reach. To do my wire work, was easier reaching in behind the hood. I may get a couple new truck side connectors though, I cut for my splices a little short, but it works. I did try that OEM DS-II but "no joy", it's still dead. Anyway, it started and run after I finished, so I didn't mess up my wires, and it's in an easier to reach place if ever I need to swap it out. My truck's OEM jack is long gone.
I did this thread just in case someone else is considering it.
I drove one 15-years up to around 295k miles, still ran like a singer. But, _ _ those electronic PMD's went south like a Dura-Spark without warning. _ _ I carried a spare.
Can we still order a FOMOCO Dura Spark from Ford today ?
I seen them claim to be on Ebay, but for the price a fellow could buy three or four over the counter and carry extras as spares. I notice my OEM had Motorcraft molded in the housing and had a non sticky brown potting, not the gooey black.
