Basic In-Cab Wiring Questions
1. What is the best entry point into the cab from the engine bay? Say a bundle of 2x 6ga wire (+&-) and 8x 16ga or so for relay triggering (lights, GPR, etc).
2. Is there any harm in running a dedicated ground wire into the cab - from the battery - as opposed to locating something to use under/in the dash panel? I cant imagine so, but maybe some smart people here have some insight. Basically this dedicated ground (and the dedicated power line) will backbone the bank of switches planned. I feel connecting directly from the batt(s) is better than jumping off existing wiring under the dash.
* My plan is to set up a circuit using a single pull/double throw momentary switch to trigger 2 different timed relays (time delay off) - which will trigger the existing GPRelay (with negative activation to replicate the PCM sig).
Why 2 times you ask? I would like a nominal 30 sec GP cycle for warmer weather starting, and then a longer cycle (like the nominal 2 min baked into the PCM) for the cold weather starting (note: in northern Maine). Since there is a risk of the L-N alternator supplying too much voltage at idle, compared to the anemic stock alternator, I dont want to run the risk of forgetting to switch off the GPR before I start cranking. This is why a momentary switch and the timers.
Forgetting to switch the GPRelay off? Well aside from age, usually when I start in the winter time I turn the key to engage the GPs and get out to a) clear snow off truck; b) deal with the extension cord for batt tender/block heater - dont need to be losing track of that thing only to get gobbled up by the snowblower, and c) those seats are awful cold to sit on while pushing a button for 3 minutes.
Plus I've never seen a single person with proof of a issue fron high voltage. Just hearsay. lol
some high output Alternator are NOT controlled by the PCM,
mine is not.
it is a MechMan 340A
but, it might have been IF, a shade tree mechanic had not butchered up the OEM wire harness to the alternator.
I had to run a new wire from the key-switch to the Alternator 'on' terminal ( I ) ??
this causes it to output 14.9 volts immediately, so I have to watch the DVM in the power port to verify that the glow plugs are OFF... I have a delay relay to install as soon as, it stops raining here
Plus I believe where the truck lives plays a role. With the PCM setting the ON time based on oil temp (for the most part), the maximum ON time appears to be when temps less than 32F, with the longest time when EOT<14F. For me I am nearly 6 months where average temp is below 32, and 3 of those months are lucky to see 14 as an average. Thus the times my GPs are on are the longest, increasing the impact of higher voltage on them. It could be that for some, their exposure to longer ON times is minimized, thus reducing the possibility of "high" voltage negatively impacting the GPs. @Y2KW57 has posted some good info from Beru (the designer and manufacturer of the GPs) about their voltage limitations. Plus I think there is a TSB on the matter.
Like I said, getting authentic GPs is getting to be challenging. Also the risk of a tip falling off and pin-balling in the cylinder would be a game over for me with this vehicle. Plus, it is a cool science project.
Pros/Cons on switching the GPs aside, I still have the main question: what is the best routing into the cab with a bundle of wires?
Use the four OEM Ford pass through wires that are already passed through the firewall, and have blunt cut heat shrunk capped pigtails under the hood and under the dash.
@RacinJasonWV recently posted a photo of the underhood location of these four pass through wires:
I still want to bring 2x 6/8ga lines in from the batts to power the switch bank. Plus I will need 1x more relay trigger lines (above noted GPRelay, fogs/driving up front, headache rack floods, rear floods, and a spare (future camper/topper feed as long as the domestic authority is onboard with one of those snazzy new aluminums that are coming out?) - for a total of 5 triggers. So I believe I will still need to come up with a firewall penetration.
Personally I like your timed relays and your logic behind them (yeah I can be forgetful too, which means plan ahead!)
In my opinion, a dedicated ground would be a good practice even though I don’t do this.
pick one and use it.
as I mentioned,
I watch the DVM in the powerport, and even in warm weather, the volts stay down around 10.5 to 11ish for more than a minute, nearly two minutes.
I don't think the PCM is controlling the 'ON' time as well as some folks think.
I bought a programmable controller so that I can set it for 2 minutes and 15 seconds.
it will keep the MechMan 340A alternator off until that time period has elapsed....
so what, if it takes a couple minutes for it to start charging?
it goes to 14.9 volts immediately.;
Then you'll have a cozy little place to sleep on all your wiring woes, when and if the Domestic Authority changes to unapproved status.
I'd keep the hot hotties out of the cab, which the Domestic Authority is not likely to approve anyway.
If all the loads are outside the cab, there is no need to bring their hot current demand inside the cab, when you can use relays underhood.
Every load you listed is outside of the cab. No need to bring 6 Gauge into the cab, much less 2x6Ga.
