49 ford f1 exhaust question?
Old Jun 8, 2026 | 11:40 AM
Chadlv's Avatar
Chadlv
6th Gear
I just installed a ford 302 in my 49 F1, need help with the exhaust, shorty headers dump on top of steering box and long headers do not fit because of steering box any suggestions? I am hoping that stock mustang exhaust manifolds will fit and allow enough room to connect mufflers. Any pictures would be great.
Old Jun 8, 2026 | 12:12 PM
52 Merc's Avatar
52 Merc
Early Mustang manifolds will work fine. I used them in my first build 45+ years ago. No pictures because it was a long time ago, but they will work.
Old Jun 8, 2026 | 12:43 PM
Chadlv's Avatar
Chadlv
6th Gear
Thank You.
Old Jun 8, 2026 | 12:47 PM
52 Merc's Avatar
52 Merc
Welcome to the forum!
Old Jun 8, 2026 | 01:16 PM
gogoat's Avatar
gogoat
I did the same install 10 years ago. I got shorty headers from Speedway.
Part # 930-0201H
Then were $225
Good luck
Feel free to ask ???s
Old Jun 8, 2026 | 01:35 PM
Chadlv's Avatar
Chadlv
6th Gear
I have shorty headers but the driver side dumps out on top of the steering box. and there is not enough room between the engine and steering box to run long tube headers.
Old Jun 9, 2026 | 12:24 AM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
What model vehicle are your current headers for? There are several configurations of SBF headers that may work for you, but before I or others offer suggestions it would be nice to know what you have already.
Old Jun 9, 2026 | 02:49 AM
1949f1's Avatar
1949f1
On my 49 I have the Toyota power steering box. I run the speedway polished shorty headers. I did sit the engine over to the passenger side about 1 inch. I have plenty of room. They run into side pipes that are mounted at the edge of the running boards
Old Jun 9, 2026 | 09:45 AM
Chadlv's Avatar
Chadlv
6th Gear
The Headers are for a 289/302 SBF they are not vehicle specific. the problem i am running into is the clearance between the engine block and the steering box mounted on the frame. The header sits on top of the steering box and if I flip the headers then it sits on top of my motor mount cross member.
Old Jun 9, 2026 | 02:34 PM
truckeemtnfords
I would look at an early Mustang Tri-Y header. Less pipes, more clearance and you can heat and pull the driver's side towards the center of the truck if you need a little more clearance.
Old Jun 9, 2026 | 02:47 PM
Chadlv's Avatar
Chadlv
6th Gear
I just happen to have a 66 Mustang with Try-Y headers on it, I will give them a try and see if it fits
Old Jun 9, 2026 | 05:12 PM
moejr's Avatar
moejr
Your motor mount look to be the tube type... how are they mounted, welded, bolted? Any adjustments?
Old Jun 9, 2026 | 05:37 PM
Chadlv's Avatar
Chadlv
6th Gear
They are bolted into the inside of the frame.
Old Jun 9, 2026 | 05:59 PM
moejr's Avatar
moejr
unbolt & modify the mount to fit...better than chasing down what headers to get that might work, try and use what ya got already.
Old Yesterday | 07:49 AM
Dturk's Avatar
Dturk
My 51 F1 has a 302, stock steering and Sanderson headers (done by PO). I’ll take a picture later today and post it. They go into down pipes with a H crossover and into Borla Mufflers. No droan and quieter than road noise at speed. But still noticeable at idle.
