TCU Telematics module
Old Jun 6, 2026 | 06:03 PM
oceanrace's Avatar
oceanrace
I have a 2024 F350, just paid it off. All good. Except that i need to locate the telematics module that transmits data to Ford and i do not want my truck spying on me.
Does anyone know where this module is located on a Ford F350 supercab truck? I want to disable it at a minimum, prefer to remove it completely. BTW, in the 2027 trucks, there will be far more invasive driver monitoring including AI and that means this truck is the last new truck I will ever buy.
Sad where electronic meddling in our lives is going.
Old Jun 6, 2026 | 08:25 PM
Poncho450's Avatar
Poncho450
If I remember correctly it’s behind the passenger side rear seat on crew cabs, not sure about SuperCabs.
I once unplugged it for a short time. You’ll lose the FordPass functions if you use those. Also map/navigation. I can’t recall if it affects fob remote start or not.
Old Jun 6, 2026 | 08:45 PM
oceanrace's Avatar
oceanrace
Mine is crew cab, my bad. I always use Waze nav on android auto anyway. And I have a Ravelco anti-theft device installed, so there is no way to remote start the truck anyway. I do not use the FordPass functions either, so i will find it and disable it.
Thanks!
Old Jun 6, 2026 | 09:14 PM
sd ford's Avatar
sd ford
Also there's a fuse 38 inside fuse box for TCU The fuse boxes on the passenger side underneath the dashboard When you remove it you're not going to have no GPS
Old Jun 6, 2026 | 09:55 PM
Archion's Avatar
Archion
Veteran: Marine Corps
Doesn't like companies harvesting data, has a smartphone...
The upload options to Ford/3rd party companies can be turned off. This also disables the gps/data features.
Next model year, thanks to our lovely members of congress with well fed pockets we may not be so lucky. Maybe Forscan will come to the rescue again.
Old Jun 6, 2026 | 10:10 PM
oceanrace's Avatar
oceanrace
Yes I have a smart phone, have done all I can to neuter that damned thing too. I don't know, may not be a huge big deal to just leave it alone. Also, Ford can do updates like the trailer towing module deal, without having to take it in to dealer for the TSB. So may be better off just leave it alone as is.
Old Jun 7, 2026 | 06:05 AM
Poncho450's Avatar
Poncho450
Thanks!
Post back what you discover in case someone else decides to go the same route.
I don't even know if the factory navigation works on my 2023 anymore. Never paid for subscription as I also use Waze with CarPlay if I'm on a trip any distance from home.
Old Jun 7, 2026 | 07:39 AM
Archion's Avatar
Archion
For reference, on the super cab it looks like it is behind the load space panel, rear of the cab behind the seats, below the tethers.
Old Jun 7, 2026 | 05:56 PM
HeatStroked's Avatar
HeatStroked
I'm going to install a switched fuse on mine, that way every couple months I'll just turn the switch on to get the OTA updates, then switch it off. Don't have to hassle plugging the module or the fuse in and out.
Old Jun 7, 2026 | 06:19 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
I unplugged mine 5 minutes after I brought it home from the dealership.
FOB remote start works fine.
You will lose factory navigation, and obviously any connectivity with the app.
Old Jun 8, 2026 | 05:09 PM
HeatStroked
If you're interested on what data you've given up through Ford Pass and the telematics unit. Contact NexisLexis and request a free report. It will have everything on you, past addresses, court issues, driving tickets, data from the TCU, etc.
You can also freeze your data.
Old Jun 8, 2026 | 07:58 PM
Charlie98's Avatar
Charlie98
Why don't you just turn it off, via the settings? That's what I do. Yes, I lose all the functionality, including OTA updates... but, as ATC mentions, the remote start fob works fine. I turn it on when I know it will be setting for the weekend, and let the updates do their thing.
Old Jun 8, 2026 | 07:59 PM
Charlie98's Avatar
Charlie98
You can also request from Ford, all the data it has mined on you (my file was something like 204 pages long...) and then request, in writing, that they discontinue collecting and selling your data. By law you have that right.
Old Jun 8, 2026 | 08:05 PM
StockHeightIsBest's Avatar
StockHeightIsBest
....When you need a post-graduate degree to undo all of the Techno-Feudalism baked into a new vehicle. Lord almighty. Mine is even flipping on my location info on my phone. And I'm not even using a navigation app; just listening to songs saved on my phone itself.
Old Jun 8, 2026 | 08:08 PM
Charlie98's Avatar
Charlie98
Originally Posted by StockHeightIsBest
....When you need a post-graduate degree to undo all of the Techno-Feud Marxism baked into a new vehicle. Lord almighty.
There... fixed that for you...
