Sponsored by: Real Truck
ZF 6 locked up but not.
Old Today | 06:13 AM
FR4x426's Avatar
FR4x426
6th Gear
Hi, I have a ZF6 transmission i received when I bought my 2003 f250 v10 4x4. I was told the transmission was locked up and got no explaination as to what happened but i came to the conconclusion it was run low on fluid due to the rotted leaking cooler llines.
Any ways, The transmission will not spin in any gear except reverse. When put into neutral it will spin over but the output will spin also and you cannot keep the output from spinning when turning the input.
The weird thing to me is when I took off the tail housing all the gear change and roller over just fine it seems.
I experimented with taking the idler gear out and put the tail housing back and which resulted in the gears all spinning over.
Now, the back story on the idler gear is when I initially took off the tail housing I found the needle bearings had let go for the idler gear. I replaced them and it did not changed any symptoms of the lock up.
I feel I am missing something in plain sight and hoping someone can shed some light. Thank you in advance!
Old Today | 10:55 AM
Super Duty DJ's Avatar
Super Duty DJ
Is the reverse shift sleeve moving to the correct position when shifting out of reverse? When you have the transmission in neutral, is the output shaft turning the same direction as the input shaft, or is it turning the opposite direction? It seems like there may be an issue with the reverse shift mechanism that is leaving reverse engaged, so when you engage another gear, you have both a forward gear and reverse engaged at the same time, resulting in lockup.
Old Today | 11:43 AM
FR4x426's Avatar
FR4x426
6th Gear
Turning the opposite direction
The output shaft is turning the opposite direction.
Old Today | 11:55 AM
Super Duty DJ
That indicates that reverse is not disengaging when you have shifted to neutral, so any time you shift into another gear you are engaged in both reverse and a forward gear at the same time, resulting in lockup. You probably have to get into the main case enough to see if the low/reverse shift fork broke, or disconnected from the shift rail or something while the shift collar is engaged in reverse. I suspect that you may find that the shift fork is broken or disconnected because there are other interlock mechanisms to prevent the shift rails from allowing multiple gears to be selected at the same time and those are almost always geometric constraints that physically lock the "inactive" shift rails in the neutral position when the "active" shift rail moves out of the neutral position.
Old Today | 02:42 PM
FR4x426's Avatar
FR4x426
6th Gear
Ok, that makes sense. I’ll give it another look later tonight. I’m not real sure how I will be able to tel so I hope it’s kinda obvious.
Pele
Jan 18, 2021 09:05 AM
Kadin Cook
Mar 24, 2016 09:55 PM
Sycostang67
Aug 4, 2006 07:01 PM
hotrob
Apr 9, 2006 08:07 PM
