HPFP - generations and changes? Detail?
I figured I would start a dedicated thread on this subject as it is a major decision point.
How would I find the production changes in the HPFP's used on the 6.7's?
The underlying question is I have a truck in the shop being repaired. The last major service was about 5 years ago with a failed HPFP. We had all through the injectors replaced at that time. Since then about 17k miles have been put on the truck. It appears now an injector is bad (among other things, but not fuel system related). I won't re-hash everything.
So where we're at with it is the truck is a 2011 job 2. The original HPFP went about 170k miles. In its current state - it has sat out of service for about 2.5 years (the first year and a half of that it was periodically driven - every month or two - for a couple miles, the last year it has not run until the other day).
While we're in process to get the truck back in-service the big question we have is - what were the changes, if any, in the pump that went on about 5 years ago vs the original OEM from that 1st model year/2nd build?
If there is a way to verify, by way of part number from the previous service, to determine any changes that may make it less likely to grenade with contaminated fuel we may be more inclined to keep going on it. However, at the moment - we are very hesitant to drive the truck on it, regardless of getting fresh fuel in it as we proceed with the work, because if the pump is already compromised it could blow at any time. And with 2.5 year old fuel that really does not give me the warm and fuzzies. The last fuel that was put in it was from October of '23. I don't want this to be a discussion topic as it is going to bury what I need to find out in "noise", but the dealer did test it before proceeding and authorized the diagnostics (which required the engine running) without a fuel flush. I'm not too happy about it, but it is what it is and we have to move forward.
Replacing the pump alone, without a fuel system kit to rebuild the high pressure system, is a $2500 job on top of what we're already having done (if it was a job in and of itself it would be noticeably higher - because there is more tear-down to do it which is already going to be done for the other work).
Ultimately - is the added $2500 justified? I say if it saves a blown pump and a whole high pressure system rebuild again in short order (it was about a $7k job 5 years ago, Im not sure what it is today) then its worth it.
Thoughts/info?
Additionally, 2.5 years is pushing it on the life of the fuel. Especially if there is any growth in it. That tank needs to be drain and fresh diesel needs to go in considering the cost of the repairs your doing here it only makes sense IMHO.
I also think there is a programing change for startup.....sometimes even in warm weather....I get a delay between push button and actiual start...my theroy is the pcm wont try to start if PSI X is not achined....could be wish full thinking.
what hasnt changed and needs to is water seperation and particle capture of fuel......I have an extra in between filter between my in tank filter and the engine bay filter....the in between filter is the only place I have ever drained water.....that does not make sense unless the intank filter can not seperate emulsifide water very well if at all.....it might be good of capturing free water .....using gravity that brings it to the bottom...but ...I have never drained any water from my in tank water drain.
another mystery about the in tank filter....I often drain particles from my middle filter....how is that possible if the in tank filter works....suspect if that rubber kids dart looking thing that seats up on the intake port....its supposed to be a one way check valve....dont know how much suction PSI it takes for the rubber dart to loose it seal and starts letting un filter fuel thru...but its happening...else...how would particles get in my in between filter if the in tank filter works?
another mystery and point of ambiguity....these so called recirculation during cold features...which I think is a ford tap dance....particles are able to ride the recirculation flow and by pass filtering.....there is some type of recirculation process in the in tank system and now there is a by pass in the engine bay filter.....does that mean by pass as in motor oil by passes...dont knoiw...but suspect is particles traveling to injectors and cp4 while these bypass/recirculation systems are engaged.
one additional benifet of the DPK is increasing the flow rate across the roller bearing s and cam...in my mind cooling effect....same effect ford try to emulate by changing the programing for the 2020 impacted vehcicles in storage problem in the hopes more flow would mean less wear.
so if you dont want to do a dcr
a. DPF
b. in between filter
c. multipurpose additives for wear, water removal, germicide, anti gel
d. if you can get bio blen that is good for cp4 lube....but bad if your truck will sit thru a tank of fuel for a while.
This would explain the big recent fuel pump (CP4) recall that only included some of the 2022 models, but not all... the recall was for the trucks that had the RP7 models. My truck was built in mid September, 2021 and is not included in the recall, so my truck was pretty close to the beginning of the switch over for the newer, better RP8 variant.
It doesn't seem like there has been as many reports of CP4 failures on these RP8 variants... or maybe I just haven't seen them all. From what I can tell, it seems like the changes from first, the RP7 and then the RP8 have made a good difference in the pumps ability to perform.
Saying that, if I were having to replace it all, especially on my dime, I would go back in with a DCR and be done with it.
