What do I need to swap it over. I made the mistake of putting R-134a in my R-12 system. Old owner said he swapped it but I learned I was wrong. It was not swapped. Now my system has R-134a in it. The compressor kicks on and works. But I would like to switch it over to a better system. What do I need to have it work nicely with R-134a? So far I think I would a need a Compressor, Accumulator, Orifice Tube and O rings. Should I get new lines for it..? Not sure about these systems. Also how do I remove the lines with the refrigerant in it? Do I just carefully remove the lines? I'm not sure if the system leaks.
And if I could is there a refrigerant you can run as a alternative to R-12? If I really wanted to I could have a shop vac it out then put a alternative to R-12 in it.
You need an "ester" oil to make the 2 oils compatible
You will never get all of the R12 mineral oil out
The ester will make the 2 oils, not form acid, and destroy your system
I'm wondering if any of you have ever been to A/C school?
Speaking to those of you who think you can simply flush the system and replace a part, any part
Buy a retrofit kit that has the fittings and the ester oil, add the oil and add the r134a after evacuating it
A small tube condenser or parallel flow will help a pile with heat rejection for the swap and make your system more efficient.
38oz of 134
11oz PAO 68
Red FOT
But if your compressor works, I would just run it as-is but yes 134 and 12 use diff oils.
EDIT - some engines had different cooling fans available, 4.9 for sure. Five versus seven blade, the more across the condenser the better. Either small block can run a 302HO fan over the steel one, moves quite a bit more air!
Obviously verify the fan clutch is good and the shroud is installed.
i have been AC certified for close to 50 years.
and i would NEVER convert a R-12 system to R134-A
the R-12 system will freeze you out of the truck.
i would flush the system real good, check for leaks, and refill with R-12.
Unfortunately I cannot get R-12. Expensive and you need a license to get it if I can recall correctly. If I could find some I would love to refill it with R-12.
38oz of 134
11oz PAO 68
Red FOT
How would a vacuum pump remove all of the oil and refrigerant? Isn't it hard for a pump to remove oil from a system? Would be nice to run the original compressor and lines. May be the case that I have to order compressor and lines with the kit. The compressor kicks on but then shuts off. Probably because the system has R-134a in it instead of R-12. As I said in the OP.
There is a flush that you can push through everything to “clean” it good enough. I did it on another vehicle and didn’t have any issues. I made sure the oil I used had ester oil in it.
all you need to buy refrigerant is an EPA 609 certificate. cost is around $25. you take it online, and can have the book with the answers in front of you while taking the test.
Exactly on the 609, plus you can learn something and answer your own questions
It flips on and off as the charge is probably super low. Go buy a nice gauge set from Mastercool or Yellow Jacket so you can see what os going on. Cheapo HF ones will work in a pinch
I'm learnin more gooder by the day on here! thx tips.
