headliner clips I heat up just to open them up a little-- never broke one yet-- the entire system is a tight set up and looks GREAT -- CAN KEEP AS IS OR PAINT it OR cover it
I glued the two side clips back on using abs glue, didn't use the velcro tabs so drilled a hole in the centre and used a push clip instead.. didn't have all this trouble when I did the pickup..
The clips on the side above the door are the hardest part of installation in the 52. Spent more time (more than I will admit) getting them in place. The instructions provided were for the old design without the clips.
