Advice to a new 150 owner
Old May 28, 2026 | 10:03 AM
Kgwest98's Avatar
Kgwest98
4wd High
I just bought a 2010 F-150 XLT 4X4 , listed with 5.4 but has a 4.6L 2V V8.It's at 298.457 miles, what are the first things I should be checking and changing?I just installed new thermostat and Burped coolant system, I noticed the previous owner was using green coolant. Should I drain the system and go oem?Truck is slightly lifted with offset wheels, the wheel has a small deadzone in the center. What could that be?Thank you for any advice
Old May 29, 2026 | 08:19 AM
explorerdriver's Avatar
explorerdriver
Different brands use different colors and its hard to know what coolant is there. There is a motorcraft flush chemical that cleans the system. Probably not a bad idea. Use Motorcraft Yellow Coolant.
A deadzone could be a worn rack.
Curious what transmission is in there. That is the Crown Vic engine usually paired with 4R75 4 speed.
Old May 29, 2026 | 02:39 PM
Kgwest98's Avatar
Kgwest98
4wd High
6 speed is what was originally in it and believe that's what's still installed 6R80 6-speed automatic transmission.
Old May 30, 2026 | 09:06 AM
Evan76's Avatar
Evan76
If it were mine i would service transmission first doing a filter & fluid change. Id then drive it for 500ish miles and dump the fluid again. I might get lazy and not change filter at 500. Might? depends on how nasty the fluid was or if i feel transmission has been negletted. Most have negletted.(weld in drain plug best transmission mod ever)
at 5000 id service it again fluid and filter.
While getting up to 5000 miles id work on changing fluid through out rig. Engine , axles, transfer case, coolant( dont care what color it is) all filters.
inspect transmission lines any metal lines that are rubbing together, chaffed, leaking scarey looking replace them, fix the rubbing
I had a expedition with the 4.6 nothing wrong with it. take care if it change oil, plugs, coil packs pretty change all consumables
Have fun with it. I realy like the f150s as tinker toy fun trucks to fix up and make nice again
Old Today | 03:40 PM
Stumblefoot's Avatar
Stumblefoot
I just bought a 2010 as well, haven't picked it up yet,, 159,163 reported miles.. so I'm watching this thread I agree with all fluids changed.. Mine was State owned so probably rode hard & put to bed wet. Body & interior pretty good..
Old Today | 06:58 PM
explorerdriver
You have the 4.6 3V. (not 2V) Those are very good motors - the Explorers had that same setup. Good chance of very high miles.
Kgwest98
2004 - 2008 F150
May 28, 2026 06:39 PM
nxtdiesel
Feb 21, 2022 11:01 PM
Nightmare1508
Nov 20, 2019 03:55 PM
jkey.bama
Jan 20, 2014 01:16 PM
BigNiner19
2004 - 2008 F150
Sep 26, 2008 10:48 AM
