Sponsored by: Real Truck
Radio issue, 2016, F250, Lariat, Crew Cab, 6.2L
Old May 25, 2026 | 02:05 PM
vjsimone's Avatar
vjsimone
When I powered up the radio this morning, I am not hearing any audio. When I got home last night, all well.
Are there any diagnostics for the sound system?
Thanks.
Old May 25, 2026 | 09:19 PM
vjsimone's Avatar
vjsimone
Update; So, I was visiting a friend of mine in hospital all day after this happened on my way there. When he was dozing out off and on I was searching the web for related issues. I did see the fuse and battery fix like you guys stated.
This evening when I left the hospital, started up my truck, everything was working.
Same thing happens with my reverse camera, it goes static like on start-up, turn off the ignition and restart, all is well.
(took it in last month for the camera recal, camera system "did not produse a code" so dealership did nothing.}
Old May 26, 2026 | 05:11 AM
2015 F-350's Avatar
2015 F-350
I would pull out the radio and check the connections in the back. Maybe corrosion of some type?
Old May 26, 2026 | 06:53 AM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
Like I said on your other thread it's a known problem and you will have to keep rebooting it by pulling the #29 fuse or just upgrade it from sync 2 to sync 3, the dealership will be of no help because it will not set off any codes.
Denny
Old May 26, 2026 | 08:04 PM
vjsimone's Avatar
vjsimone
That's a good idea, I've been wanting to check the antenna connection anyway since this truck has the worse reception than any other vehicle I've owned or ridden in.
danieln7695
Oct 10, 2023 06:28 AM
Btmanpa
2009 - 2014 F150
Jun 10, 2022 09:16 AM
garydmundy
May 25, 2011 11:11 AM
KSims1868
Jun 9, 2009 01:19 PM
