Have a 390’fe c6 transmission. Does a cotter pin go on kick down arm and linkage? I changed rear main and had to pull trans didn’t take a picture of linkage before I disassembled (learning experience) just need help on how the setup is so I can hook back up. Thanks a picture would help or explanation on where e clamp goes too.
Right, a little spring loaded clip on both ends on the kickdown rod itself and conventional C clips on the rest of the linkage
You should be able to get those little clips still
Same ones were used on GM products for years and years too IIRR
Thank you to all in this thread for your input and help! Just fixed it, got the e clip on the kick down, put the rubber bushing in the right way then got the rod through and the cotter pin on. Thank you!
