RV Tire Pressure
Check and set all my tires to the recommended 80psi about 5 weeks ago. Since then the heat has hit and they now read 84psi on my TPMS. Leaving for cooler climate tomorrow for a week so I'm sure they will drop once they sit for a day or so. Its only 60 miles in the heat before I get to higher elevation.
Do I drop them or tow with them 4psi higher.. it's a battle because if I leave them alone they will increase hut if I drop them they will be low when I leave camp to return home.
Its a constant battle when living in the desert and camping in the mountains..
Take an average and drop them 2psi? Or leave them alone?
If you can, check the tires before setting out, and while they've all been in the shade if possible.
I agree, I would check the morning you're leaving, if they are at or right around 80 then run with it, if they're above while in the shade drop them down to it. Depending on how much cooler it's going to be, it may not make much difference.
Denny
i bet if you scaled it, you wouldn't need to be at 80 psi.
as denny said, but in different words, you are over thinking it.
set the pressure before you head out and then stop fussing over it. Pressure is dependent on ambient temperature and barometric pressure. What do you think happens to your air pressure in the tire as a storm rolls in and the barometric pressure drops? The absolute pressure remains the same, but the gauge pressure will change - sometimes as much as a full PSI, but are you going to adjust for it as the weather changes? Doubtful
Show me your scale ticket and i'll help you get what the absolute minimum pressure is - i bet it is MUCH lower than you'd expect. I'd be willing to bet, that even with a heavily loaded trailer the math would show you to be safe well down into the 60 psi range.
you are in the weeds. set it and forget it. spend time worrying about something else.
FWIW, i've tended lately to run more lower than higher. The scale tickets tell me what i NEED and i adjust it close to that number. I've found that the tires wear better when they aren't aired up far above what the weight calls for. They can scrub more in the turns, though, so that's a thing .... but by and large, i've found that they wear more evenly across the tread face - for both the trailer and the tow vehicle.
Practically speaking, this means checking tire air pressure before the first trip of the day (ie pre trip inspection). It doesn't have to be in the morning, if one does not drive during the day. If one sleeps and plays all day, and drives all night to the next destination, arriving at a camp sight in the morning, then it would not make sense to check air pressure first thing in the morning upon arrival, because the tires have been working all night to get there. This isn't said to say that you have done this... it is simply said as an example to help define the meaning of "COLD".
"COLD" in Arizona is different than "COLD" in North Dakota. Cold in terms of tires are tires that have been at rest for several hours, allowing all of the frictional heat build up to dissipate and settle down to ambient temperature in whatever climate you happen to be in.
There is one RV tire offered in the 16" wheel size that is Load Range E and is rated to 90 PSI, even though there is no difference in weight carrying capacity of this particular tire between 80 psi and 90 psi. (Michelin Agilis Cross Climate LT)
The Load Inflate Index Table for this LT tire has the same maximum capacity for every pressure increment above 80, up to 90. For this and other reasons, I selected this tire for my unused RV (Class C Motorhome), just to give the warm fuzzies whenever or if taking long drives over hot asphalt on sweltering days in summer months... all conditions that would cumulatively build up internal and external tire heat, which increases the pressure inside the tire by several PSi.
Even though inflated only to 80 PSI cold, Load Range E tires can reach 87 PSI when operated... and we have no choice but to assume that good tires manufacturers understand this, and build tires accordingly. Under this assumption, there is no need for an LRE tire to be rated at 90 psi, in order to safely operate at 87 psi, when inflated to 80 psi COLD.
