Using a Chinese 1BBl on my 300 temporarily
Old May 11, 2026 | 08:29 PM
fatheroftwo's Avatar
fatheroftwo
The place for the ported vacuum is just a hole, not sure if is operational, here are pics of the old and new
carb, anyone know where the ported vacuum fitting for the distributer vacuum hose should go?
the port near the throttle pivot is missing, as you can see, I hooked my dist. vac. hose down below
old carb, tube is there, and dist was connected there.
Old May 13, 2026 | 10:14 AM
FuzzFace2's Avatar
FuzzFace2
It looks like you got a 83> feedback carb and not the later type. That is why I tell people to look for one for a 81 300 six motor as we know that is non-feedback
Feed back = no vacuum for the distributor.
You can run it without vacuum, plug the supply, it might just be a little doggy is all.
Now if you are looking for something to do you might try and drill that out and see if it gets vacuum.
It is does you can geta small tube and drive it into the hole you just drilled and hook the hose to it.
Use grease on the drill bit to catch the metal shavings from going into the carb. If you cant get vacuum, remember you have to have the RPM above idle, you can just put RTV or a small screw with RTV in the hole.
Dave ----
Old May 13, 2026 | 03:06 PM
fatheroftwo
There won't be any drilling going on, We have done some extensive research on the ported or non ported
vacuum advance, the only difference is at idle. I am going to run the vacuum from the vacuum tree under
the intake for now.
Old May 14, 2026 | 05:59 AM
FuzzFace2's Avatar
FuzzFace2
the intake for now.
Well factory used ported vacuum that does not effect the idle till you give a little throttle and that port then gets vacuum.
Yoi are going with manifold vacuum and that is fine, I have never tried that and maybe I should on my truck as I get pinging more so when pulling the trailer.
They say going with manifold vacuum that when under load like pulling the trailer you loose manifold vacuum and no more advance timing.
Let us know how it goes.
Dave ----
Old May 14, 2026 | 09:47 AM
fatheroftwo
I watched a video by Tony I believe it was, and he went al lthrough the ins and outs of ported vs non ported.
He showed where the port was in the carb, and also showed a vacuum gauge as he drove and at idle.
Once the engine was off of idle, there was absolutely no difference between ported or non ported. He
recommended ported due to the poor performance off of idle I believe. Can't remember. I'll surely add to
this post if I ever get this truck on the road. I am very close, I believe. lol
Old May 15, 2026 | 08:51 AM
FuzzFace2's Avatar
FuzzFace2
I know this has been a "thing" for a long time and all I can say is give it a try both ways and see what works for you.
I am old school and have a hard time going to manifold vacuum for the distributor vacuum even just to try but I should on my truck just to see
Dave ----
Old May 15, 2026 | 10:37 AM
fatheroftwo
Same here, old school as well, but I have always been one to buck the system. lol
Old Today | 07:27 AM
Greg Rogers's Avatar
Greg Rogers
I have 2 china carbs for mine- I had a tank issue and thought it was a carb problem w/ china carb- but it wasn't - they went on clearance I guess from $80 to $50 so I just got another. Hate to say it but they are really good- I plan to leave mine on. I just ordered a carb for my buddies 54 Chebby 235 six cyl. We'll see how that works, also I have changed weed wacker, sno blower and lawn mower cars w/ chinas and work great. Carb for weed wacker was about size of a quarter and cost 12 bucks shipped!
JLBA210
Aug 13, 2025 12:26 PM
rthenry145
18
Jul 27, 2018 03:13 PM
stephenok711
May 10, 2012 08:40 PM
PDXF250
Feb 4, 2012 03:02 PM
Jeremy Ruppert
Oct 8, 2009 07:21 AM
