1994 F350 5.8 Oil cooler insert options
Old Apr 27, 2026 | 05:52 PM
ronhammond's Avatar
ronhammond
6th Gear
Hello- 1994 F350 with 5.8 gas. All at once oil started leaking where the oil cooler insert connects to the block. Went to NAPA and the part F4TZ-6L626–A is no longer available from Ford. Didn’t see it on other aftermarket sites either.
I read that some people have removed the cooler, installed a new filter nipple, replaced the bottom radiator hose with one without the connections to the cooler, and installed a different filter. So the question is:
Anybody know exactly what parts are required for this option, or does anybody know of a replacement for the factory cooler. I’m good with either, as I don’t tow or haul much these days. Thanks for your wisdom.
Old Apr 27, 2026 | 08:36 PM
R&RFord's Avatar
R&RFord
You need this?
Old Apr 27, 2026 | 09:42 PM
Wheezingthunder's Avatar
Wheezingthunder
Maybe swap the o ring from the old filter onto the cooler sounds like the cooler is fine but the o ring is leaking
Old Apr 28, 2026 | 10:32 AM
1Butcher's Avatar
1Butcher
I am a fan of oil coolers and liquid coolers are on the top of my list. I would not remove the cooler unless it was to get me home. I agree with @Wheezingthunder . Take off the cooler and replace the rubber seal. Maybe the fitting is loose causing the seal to leak. It would replace the seal no matter what happened.
While you are there, how is the rubber coolant hose?
Old Apr 28, 2026 | 11:24 AM
ronhammond's Avatar
ronhammond
6th Gear
Thanks for the info folks. I’ll remove the cooler and check it out and replace the two hoses and o ring if it’s not the cooler itself. Will let you know if I need to find a replacement.
Thanks again
Ron
Old Apr 28, 2026 | 12:23 PM
ronhammond's Avatar
ronhammond
6th Gear
Thanks again
Ron
Old Today | 04:53 AM
ronhammond's Avatar
ronhammond
6th Gear
Update- took out the leaky oil cooler, replaced the lower radiator hose with one for a 5.0 without oil cooler routing. Turns out when you remove the piece holding the cooler to the frame the threaded piece still attached to the block will accommodate a Napa 1515 oil filter perfectly. Put everything back together, put in new antifreeze, added oil, and no leaks and good oil pressure.
Old Today | 05:41 AM
90project5.0's Avatar
90project5.0
Good deal! Thanks for following up!
hanksmith
Nov 29, 2022 02:09 PM
justcruzin125
Dec 13, 2015 06:48 PM
towrig302
Sep 3, 2004 10:58 PM
AzPete
1978 - 1996 Big Bronco
Mar 28, 2004 02:10 PM
