Forscan and EZLynk Tune
Old Apr 15, 2026 | 12:54 PM
BenFranklin's Avatar
BenFranklin
So I made a bunch of changes with forscan, and I'm looking at getting some ECM and TCM tuning done. However I saw a note on a different forum about possibly having to revert your forscan settings back to stock in order to tune. Can anyone verify if this is the case? I'm not sure that I backed things up correctly lol.
Old Apr 16, 2026 | 07:29 AM
23F250ID's Avatar
23F250ID
One of the Few
Veteran: Marine Corps
I have ECM and TCM tuning and didn’t have to revert back to default Forscan when I did it. I guess it would depend what tunes you have and what you changed in Forscan.
Old Apr 16, 2026 | 07:42 AM
BenFranklin
Thanks for that information. Would you mind sharing who you went with for tuning? I assume EZLynk for device?
Old Apr 16, 2026 | 08:01 AM
23F250ID's Avatar
23F250ID
One of the Few
I went with AMDP for tuning on an EZLynk.
Old Apr 16, 2026 | 11:19 AM
BenFranklin
You happy with the results? Did your shifting strategy improve?
Old Apr 16, 2026 | 11:23 AM
23F250ID's Avatar
23F250ID
One of the Few
Very happy with the results. Shifting is much better and no more 3-4 flare as others have reported.
Old Today | 04:12 AM
zunepuh's Avatar
zunepuh
4wd Low
Originally Posted by BenFranklin
So I made a bunch of changes with forscan, and I'm looking at getting some ECM and TCM tuning done with an EZ Lynk tuner. However I saw a note on a different forum about possibly having to revert your forscan settings back to stock in order to tune. Can anyone verify if this is the case? I'm not sure that I backed things up correctly lol.
No, you usually do not have to revert FORScan changes before ECM or TCM tuning. Only exception is if you changed PCM or TCM or torque or transmission related as built values then some tuners may want it returned to stock. Otherwise BCM IPC and similar tweaks will not matter.
Old Today | 07:23 AM
23F250ID's Avatar
23F250ID
One of the Few
I did not have to revert my ForScan changes back to stick to use my ECM and TCM tunes.
Old Today | 07:49 AM
ZooDad's Avatar
ZooDad
Retired guy fixn stuff
As others have stated, no need to revert ForScan changes
ZooDad
Steelehill
6.4L Power Stroke Diesel
Nov 1, 2025 12:50 PM
joey schaffner
2009 - 2014 F150
Nov 20, 2012 10:08 AM
BuCKxWiLD
Mar 16, 2010 09:54 PM
tippmann87
Mar 6, 2008 10:33 PM
Nasty
Computer Chips & Tuners
Jul 24, 2003 07:21 AM
