223 no spark - why?
Old Feb 16, 2026 | 06:39 AM
Harrier's Avatar
Harrier
223 no spark - why?
To quote Bobbytnm "This is a stupid F***in' hobby!!"
My son on Friday @Kirby32 "Buy an old truck, you said. We can work on it together, you said. It will be fun, you said!"
We don't seem to be getting any spark, what do we try next?
  • New battery cables 2 awg wires.
  • New spark plug wires
  • replaced condenser
  • New coil
  • We are getting power to the distributer
  • The distributer cap and rotor look new
What next?
Old Feb 16, 2026 | 06:49 AM
55F250's Avatar
55F250
AirForceVet
Where do you seem to be not getting spark? At the points or at the plugs?
Old Feb 16, 2026 | 06:52 AM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
It seems you did everything except replace the points - the look somewhat nasty in the picture provided.
Old Feb 16, 2026 | 08:28 AM
Brian1950F4's Avatar
Brian1950F4
Nothing to do probably with no spark, but wires should be 2/0 for 6 volt. #2 is probably ok for 12 vol
Old Feb 16, 2026 | 08:37 AM
52 Merc's Avatar
52 Merc
As I see the picture, the points are up on the cam and the points should be open, but they look closed. Find your .017 .025 (for 6 cylinder engines, .017 is the V8 gap, sorry) feeler gauge and set the point gap. Check that ground wire under the screw on the points and make sure that has continuity.
Old Feb 16, 2026 | 09:40 AM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
Good catch Wayne. The other thing is I don't see the wire from the coil connected to the points.
Old Feb 16, 2026 | 09:42 AM
8pack's Avatar
8pack
I bought the Pertronix Electronic ignition bolt in module. It replaces the condenser, points and rotor. I think it turns it into a Hall effect ignition. I wasn't super cheap but it took one variable out of trouble shooting and adjusting and I think increased reliability.
Are you sure the rotor top tab is properly positioned?
Are you sure the shaft that goes down into the oil pump is not rounded off. Mine was shot and need to be replaced.
Here is my post on it which includes the following electronic ignition. And below it is the shaft. Melling IS43
https://www.ford-trucks.com/forums/1...l#post21407689
https://www.rockauto.com/en/moreinfo.php?pk=8309056
Old Feb 16, 2026 | 05:57 PM
hooler1's Avatar
hooler1
Yes sir, I dont see one either. If you look just to the upper right of the points mounting and grounding or breaker plate screw, and look really closely at the connecting block on the points, you will see a wire that connects to the condenser. Just underneath that there looks like ring terminal that looks maybe looose and like the crimp body of that terminal facing up with the wire broken off. The points also look fairly oily and I wonder if the points contacts have grease, oil or dirt on them.
A good test to see if your points are indeed closing and is grounding the coil is testing the voltage on the points side of your coil. Engine not running with the key on and the points open you should see I think around 5 to 6 volts. Roll over the engine to close the points and the voltage should drop down to about a tenth of a volt or less if I remember correctly.
Hopefully I described this correctly. Its been a while.
Old Feb 16, 2026 | 10:22 PM
bassdr's Avatar
bassdr
Agree points look closed when they should be open. And that little braided wire under the screw can be problematic
Old Feb 16, 2026 | 10:40 PM
EffieTrucker's Avatar
EffieTrucker
Phantom of the Phorum
It looks like the points are open, but probably not enough. It also looks like the clip for the coil wire is there (red arrow) but it's not fully engaged. It's hard to tell but there might not be a wire on it.
Grease can be conductive. The inside needs a good cleaning. The points look to be carbon scored. They could use a little polishing with super fine Emory cloth/paper.
Old Feb 17, 2026 | 07:21 AM
PLM1955's Avatar
PLM1955
When I was a teenager, I worked in a lawn mower shop. Any time we had a no spark situation, we cleaned the points with the corner of a rag dipped in gasoline. It was surprising how many times, that would cure the problem. Years later, I used that same technique to get the small block v8 engine to run in a boat.
Old Feb 17, 2026 | 08:40 AM
Harrier's Avatar
Harrier
I used a nail file on the points and it was gapped at 19. I will double check and also go through all your suggestions....when I get to the shop next...
Old Feb 17, 2026 | 02:59 PM
52Flthed's Avatar
52Flthed
I had the same problem on my truck a few weeks ago, no start situation. Turns out the points were out of adjustment, Spark plugs were fouled from trying to start it. But what was pointed out to me was that the adjustment screws are supposed to be Fillister Screw head as well as have a star lock washers on them, thus preventing; the screw from getting stripped easily, and it readily going out of adjustment. Mine without the lock washer went out of adjustment in a year and half.
Old Feb 18, 2026 | 05:37 AM
ManFordman2's Avatar
ManFordman2
That coil wire clip looks like it may be grounding out on the points plate.
Old Feb 18, 2026 | 12:33 PM
Harrier's Avatar
Harrier
Good eye! I will fix that and see what happens.
