Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1969 F700
Old Dec 7, 2025 | 08:38 AM
Franklin77's Avatar
Franklin77
8th Gear
1969 F700
Well iam new to the site. I have a 69 f700, actually it’s peashooters old truck. I have a question. I want to change the 2 speed rear end to a newer one . I don’t like that just to do 50 mph it has to be over 3000 rpm. Iam not looking for speed , I just don’t want to feel like iam killing the motor . Also I was thinking since you can’t get brake drums for them , I could get one that u can.
Old Dec 7, 2025 | 10:47 AM
asavage's Avatar
asavage
FTE Community Team
Is yours stuck in Low?
Availability of brake drums isn't an issue if you don't need one. IOW, don't let the brake shoes get worn to the rivets and the drums last longer than the truck. Even then, used ones can be found, though not cheap.
I have no advice about a newer replacement rear axle, though it's been brought up in several threads.
Old Dec 7, 2025 | 11:53 AM
Franklin77's Avatar
Franklin77
8th Gear
Low and high gears work , 4th gear high is just to do 50 mph it’s over 3000 rpm,
Old Dec 7, 2025 | 11:54 AM
asavage's Avatar
asavage
FTE Community Team
Ah, so geared as a fire truck or city delivery. Yeah, that's annoying if you want to move between cities.
Old Dec 8, 2025 | 02:10 PM
shaun.be's Avatar
shaun.be
What gear ratios do you have now? I will have the axles that are in my 68 n700 available for sale in the near future if you might be interested in them, let us know your stock ratios and ill find what mine are and maybe it will be a match for you.
Old Dec 9, 2025 | 05:55 PM
Franklin77's Avatar
Franklin77
8th Gear
I believe they are 6.50/ 9.04, but iam not 100% sure.
Old Dec 9, 2025 | 06:41 PM
asavage's Avatar
asavage
FTE Community Team
That 6.50:1 is about right for most gas engines of that era with the 20" wheels they came with. My '73 has 6.17 high, my trans is direct 5th, and the engine sounds happy (though noisy) at 65.
Old Dec 9, 2025 | 07:45 PM
85e150's Avatar
85e150
Do you have the axle code from the warranty plate?
Old Dec 10, 2025 | 05:53 PM
Franklin77's Avatar
Franklin77
8th Gear
I’ll have to look , I’ll check Saturday. By the time I get home from work it’s dark.
Old Jan 12, 2026 | 06:09 PM
Franklin77's Avatar
Franklin77
8th Gear
Clutch
Have another ? My 69 ford f700 trying to find new clutch , it has 4 speed transmission . I believe it’s original new process 435 . My old clutch doesn’t have any numbers on it , does anyone know what clutch iam looking for.
Old Jan 12, 2026 | 09:22 PM
asavage's Avatar
asavage
FTE Community Team
Which engine?
Assuming a 330 M/D, 330 H/D, 361, or 391 . . . and that's it's still somewhat original at 55 years old . . .
7548 Clutch release bearing D1TZ-7548-B, $38-60 via eBay
7600 Pilot bearing C4TZ-7600-C, as cheap as $15 for NOS via eBay
Further assuming a 13" clutch (11" & 12" clutches were offered for various gas engines) . . .
7550 Disc. Assy. C5TZ-7550-H
7563 Pressure plate C6TZ-7563-C
But you're probably not going to buy Ford parts. See this thread for more info on 13" clutch kits.
Old Jan 13, 2026 | 06:18 PM
Franklin77's Avatar
Franklin77
8th Gear
It is 13 inch , thanks for the info , that helps a lot.
Old Yesterday | 11:36 AM
Franklin77's Avatar
Franklin77
8th Gear
1969 F700
Just wondering if this is the right shifter. It should have pins in the side to hold the ball in , but I don’t see them. Mine has a big spring on the underneath which I don’t see any where.
Old Yesterday | 12:56 PM
asavage's Avatar
asavage
FTE Community Team
A clear picture of your truck's Warranty Plate would be very helpful. It's typically located on the driver's door, below the latch.
That doesn't look like an NP435 top cover to me; it has only four bolts to affix it to the trans. A 4-bolt shift tower is used on the C-series adapter for the NP435, but it also doesn't look like that.
[later] It looks like a Clark 280-series 5-speed.
Yes, it looks like yours is missing the coil spring and seat. Let's hope the seat isn't in the bottom of the transmission. Without the transmission tag info (right upper side of a Clark 280), it could be C6TZ-7227-D or C8TZ-7227-A or something else.
https://www.ebay.com/itm/143479312454
But that might not be the right one: I need a pic of the trans ID plate, like this:
The Seat seems to be the same part number for all the 280s: TGAA-7228-A, lots of those available.
https://www.ebay.com/sch/i.html?_nkw=TGAA-7228-A
Old Yesterday | 02:09 PM
asavage's Avatar
asavage
FTE Community Team
I've merged your older threads about the rear end and clutch to this one about the shifter; it's much easier to answer questions about your truck when the info is in one place.
