How to test PCM-controlled alternator?
Old Dec 1, 2025 | 12:23 AM
CathedralCub's Avatar
CathedralCub
FTE Community Team
I want to test a PCM-controlled alternator. How would someone go about doing this? Ideally, I'd like to test output at different duty cycles without involving the PCM.
Thanks!
Old Dec 1, 2025 | 08:07 PM
Franklin2's Avatar
Franklin2
Unplug" test (for some systems like Ford)
  • Unplug the pigtail:
    If your vehicle has a smart charge system, unplugging the main pigtail from the alternator will cause it to go into "default" mode.
  • Check the voltage:
    If the alternator is working correctly, it should now output a fixed voltage, typically around
    13−13.5v
Old Dec 3, 2025 | 11:32 PM
CathedralCub
FTE Community Team
Great, thanks!
Old Dec 14, 2025 | 12:47 AM
CathedralCub
FTE Community Team
    13−13.5v
I got to thinking about this a little bit today. What is "default mode"? Is it "charge like an old fashioned pre-smart-charge alternator and will attempt to charge all the time up to its rated capacity" mode?
Old Dec 14, 2025 | 12:54 AM
KULTULZ's Avatar
KULTULZ
What are you working on?
Old Dec 14, 2025 | 08:07 AM
Franklin2's Avatar
Franklin2
How it Works
  1. Normal Operation: The PCM sends pulse-width modulated (PWM) signals (GENCOM/GENMON) to the alternator's regulator, telling it to vary voltage (e.g., 13.5V to 14.9V) based on engine load, battery state, and fuel economy goals.
  2. Default Activation: If the PCM can't communicate (e.g., a disconnected wire, internal fault), or a specific condition is met (like high RPM with low load), the regulator defaults to a basic voltage.
  3. Default Voltage: This usually settles around 13.7V - 14.0V, providing enough charge without the sophisticated adjustments.
  4. Diagnostic Test: You can test this by unplugging the regulator's connector; the alternator should then output this default voltage, confirming the generator itself works, even if the smart system is faulty.
Guess why they do all this? Fuel mileage. It's this crap that hopefully they will do away with after Trump got rid of the 50 mpg fuel mandates. It's also why oil looks like water now when you pour it into the engine.
Old Dec 14, 2025 | 04:44 PM
CathedralCub
FTE Community Team
How it Works
    • Default Activation: If the PCM can't communicate (e.g., a disconnected wire, internal fault), or a specific condition is met (like high RPM with low load), the regulator defaults to a basic voltage.
      • Default Voltage: This usually settles around 13.7V - 14.0V, providing enough charge without the sophisticated adjustments.
        • Diagnostic Test: You can test this by unplugging the regulator's connector; the alternator should then output this default voltage, confirming the generator itself works, even if the smart system is faulty.
Thank you for this concise explanation!
For this, I just want to make sure I understand for my purpose: When the regulator defaults to basic voltage, this is the same as a pre-smart-change alternator, right?
. . . and it will charge up to its rated capacity (provided there is demand and it is spinning fast enough etc. etc.) ? Like if it is rated for 140 amps at a certain RPM it will charge at 140 AMPS at a certain RPM, etc.?
Can it run this way indefinitely?
No kidding. I wouldn't have the heart to run any big V-8 (or V-10) on thin oil like that! GM is having quite a time with thin oil right now. A few others are as well. I have a friend that has an early 20-teens CRV that takes that 0W20 swill, and it seems happy with it even after a lot of miles. It appears that it was well-designed for that though, and most of them seem to do okay even though they are ~10HP/liter more powerful than a GM 6.2. If it wasn't for the silly oil-change cover on the belly pan, it is a quick oil change because it pours out and in really quickly!
Old Dec 14, 2025 | 04:54 PM
CathedralCub
FTE Community Team
Let's just say for now: I'm working on something that will pretty much never need to stop charging and/or supplying high-power accessories, and that I'm not worried about the alternator's impact on fuel economy. More to come on this, but I don't want to hijack my own thread quite yet.
Last edited by CathedralCub; Dec 14, 2025 at 10:51 PM. Reason: Removed a redundant word
Old Dec 14, 2025 | 05:58 PM
Franklin2's Avatar
Franklin2
From what little I know, I would say negative, the alternator will not act like it was designed and not be like a pre-smart alternator. I do not know about amperage output, but I can see in this "limp" mode it is not putting out the proper voltage that a newer alternator should. All newer alternators, I would say late 80's up put out about 14.5v when the engine is running above idle. The older alternators put out around 13.5-13.8 volts. While the alternator in limp mode would most likely keep things going, it doesn't look like it has it's full output rating to me.
Old Dec 14, 2025 | 10:55 PM
CathedralCub
FTE Community Team
Interesting, okay.
13.5+ volts is still charging, an that's about the most I'd ever see out of pre-2000ish alternators on anything. I'd be okay with that.
Does anyone else have some experience that might help clarify this?
command37
Jan 9, 2016 09:36 AM
Encho
21
Apr 6, 2013 11:25 AM
02GrayPowerStroke
Feb 3, 2007 01:23 PM
beaker420
Electrical Systems/Wiring
Aug 9, 2004 10:58 PM
roc.r1
17
Feb 8, 2004 02:38 PM
