22+ headlight conversion
Old Oct 9, 2025 | 03:39 PM
Stink_Whistle's Avatar
Stink_Whistle
Anyone thats done this swap on a 17+ make any progress on the bright lights working? I never could find a wiring diagram of the 22 headlights so just kind of gave up in December.
Old Oct 9, 2025 | 05:34 PM
Joe T's Avatar
Joe T
You mean 2017-19 to 2020-22?
These guys make the harnesses. I would recommend them for sure.
https://retrocustomz.com/shop/ols/ca...sion-harnesses
Old Oct 9, 2025 | 08:03 PM
Stink_Whistle
I don't need the harness as Ive already repinned the oem harness. I was just curious if the brights have been solved yet.
Old Nov 5, 2025 | 07:24 PM
downsouth's Avatar
downsouth
4wd Low
How far did you get with this before you gave up? I am going to do the 17-19 to 20-22 facelift and really dont like any of the aftermarket headlight options, but am struggling to put in headlights that wont have high beams. I have ordered a functioning OEM LED headlight with a broken housing and front lens to do some testing on. It will be here tomorrow. I'd rather not start from scratch if you have already found out anything that could be helpful.
Old Nov 5, 2025 | 07:46 PM
Stink_Whistle
I was able to get the brights to work with the truck off with the use of the lever and that's about it. Never found a wiring diagram for the 20-22 lights to see what the other pins were for. Also tried a different ballast part number which made the brights come on all the time.
Old Nov 5, 2025 | 07:56 PM
downsouth's Avatar
downsouth
4wd Low
I'm thinking to go a little more neanderthal on it - use an adapter harness for all functions except high beams, and tap straight into the high beam wiring AFTER the ballast (inside the headlight housing). Trigger them from a relay off the factory high beam wiring at the old headlight harness(es). No idea if it will work or not, but will find out tomorrow when I cut open a stock LED housing. 🤣
Old Nov 6, 2025 | 06:59 AM
Summers22's Avatar
Summers22
If going 19 halogen to 22 halogen, all the wiring is the same?
Old Nov 6, 2025 | 07:00 PM
downsouth's Avatar
downsouth
4wd Low
I got the test light in today and got into it. From what I am seeing, it looks like pin 3 is the high beam trigger. Still need to trace a lot of wires (there were way more in the housing than I expected).
Old Nov 7, 2025 | 06:40 PM
Chrs.Jons's Avatar
Chrs.Jons
Following this, A while back I updated my 2017 F350 Lariat with Morimoto hybrid headlights. The truck originally had halogen lights. I’ve been considering upgrading my 2019 F250 Platinum to the 20+ OEM LEDs, but I’ve held off because I want to do the update with the OEM headlights and need the high beams.
Old Nov 11, 2025 | 02:48 PM
Stink_Whistle
@downsouth Nice work so far. Keep me posted and if you need a ballast to test I'll send you one. Were you able to locate a pin out for the 20+ light?
Old Nov 11, 2025 | 02:49 PM
Stink_Whistle
I'm not sure on the halogen. On the LED both plugs are the same but you have to repin the oem plug or waste $$ on an adapter harness.
Old Nov 11, 2025 | 07:43 PM
downsouth's Avatar
downsouth
4wd Low
I will need one at some point, thanks for the offer. I have the wiring diagrams for the truck side 20+ connector, and am still chasing wires for the headlight side. I finally was able to see a 2020+ OEM headlight in person this weekend and I am pretty sure that I have figured out what individual LEDS are the high beams that we need to activate. It looks like the 3 across the bottom row are low beams and the 3 across the top are high beams. I couldn't tell any difference in the lower LED assembly at all (I was wondering if they had a shutter that opened up to reveal he full beam, but couldn't see any evidence of that). If anyone has 20-22 LEDs can confirm, it would make this much simpler than I expected.
Old Nov 12, 2025 | 11:19 AM
Chrs.Jons's Avatar
Chrs.Jons
That sounds encouraging!🤞
Old Today | 02:22 PM
Stink_Whistle
Any update on bright lights working?
Old Today | 02:36 PM
downsouth's Avatar
downsouth
4wd Low
I was able to get the headlight cut open and get the LED module out, and identify the pins on its harness for each of the individual LEDs. The only power supply I had easy access to was a 15v, and I hit one of the high beam LEDs with 15v and it fired right up, and then after about 5 seconds burned it out. I have 2 more high beam LEDs in the module to play with and am going to source a 12v power supply to try. If it fries the LED then I'm at a loss as we don't know what voltage they are getting from the trucks headlight module. For the time being, I installed a set of 22 OEM halogen housings to get my by until I can focus on the LEDs again. As the halogen housings are starting to fog, that timeline is getting shorter, but I did buy another project truck I've been playing thats eating up my play time.
