Trying to start
Old Dec 18, 2024 | 02:19 PM
Daniel Yosef's Avatar
Daniel Yosef
Trying to start
Hey , just changed a starter, re wired ignition. Its a 67 f100.
it seems like i get a reaction but truck wont start.
do you think its a carb issue?
Old Dec 18, 2024 | 02:46 PM
jzjames's Avatar
jzjames
Reaction meaning it tries to fire up?
put a little gas down the carb and see if it fires up.
Old Yesterday | 10:08 AM
1974Ranger's Avatar
1974Ranger
4wd Low
Thanks very much for all the tips, guys. Now I've got a good checklist to run through. I'll report back after.
Old Yesterday | 10:54 PM
GeneT's Avatar
GeneT
By reaction, you mean it's cranking (turning over) but doesn't catch? Starter fluid works as an alternative to gas if it's turning over but not starting for a possible gas issue.
But you just re-did the ignition so electrical is a consideration, if the gas check doesn't give a result it might be worth verifying that you're getting spark at the plugs. If you have a spare plug lying around, you could pull one of the plug wires, hook it to the spare plug, ground the plug and have someone else crank the engine and see if you get spark. It's not a bad idea to wear gloves.
greenmachine55
Large Truck
Sep 16, 2023 09:17 AM
Jobbenils
May 10, 2022 01:27 AM
Kennewick
Jun 21, 2009 09:50 PM
harleymarkt
Jan 25, 2009 04:24 PM
hammerdn
Feb 4, 2006 09:56 AM
