1951 wiper mod
Old 05-23-2024, 08:21 PM
movingdirt's Avatar
movingdirt
movingdirt is offline
1st Gear
1951 wiper mod
Updating my 51 and can not bring myself to spending hundreds on wiper motor kit. Currently have 2 wiper motors and work off of 2 different switches.
Anyone have ideas or donor vehicle to get an assembly from to simplify this?
Old 05-23-2024, 08:33 PM
bmoran4's Avatar
bmoran4
bmoran4 is offline
If your patient and lucky, you can find the stock Bosch electronic motor setup. That is what I run in my trucks. Just be sure to clean and grease the gearboxes.
Old 05-24-2024, 11:06 AM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
I went thru several iterations of stock electric and aftermarket setups. With the stock pivots, you can only get a full sweep by using the factory electric setup. Ultimately I went with the Dennis C. replacement, with their pivots, and it is excellent. Not cheap, but it works when you need it. Their pivots are greatly improved, too. See the thread here about them: https://www.ford-trucks.com/forums/1...d-1950-f1.html
I tried a kit from New Port Engineering that provides just a new (12v) motor for 51-52's, and it was a complete failure and waste of a couple hundred bucks.
Old 05-24-2024, 01:30 PM
hulleywoodworking's Avatar
hulleywoodworking
hulleywoodworking is offline
Is this the one you used?
I have the Newport and don't like it; the sweep is just a tad too much for the OEM arms, so I had to disconnect the passenger wiper arm for it to work. Told Newport about it but they are positive that their motor is correct. So I want to replace it.
Old 05-24-2024, 01:32 PM
hulleywoodworking
This kit is out of stock, unfortunately. Is this the one you used, or was it the one in my last post?
Old 05-24-2024, 02:22 PM
ALBUQ F-1's Avatar
ALBUQ F-1
The reason the New Port retrofit kit doesn't work is due to the geometry of the arms on the pivots. Their motor tries to pull at an angle that causes distress. I talked to them at length and got nowhere.
I believe the one I have is the second one. The first one looks a lot like the New Port retrofit system.
Ryan50hrl
2004 - 2008 F150
07-25-2023 09:49 AM
Parker538
06-28-2020 06:04 PM
harley4jcs
01-11-2015 06:20 PM
Matrim
02-15-2014 12:44 PM
Limoguy
10-17-2013 11:33 PM
Quick Reply: 1951 wiper mod
