1951 wiper mod
Anyone have ideas or donor vehicle to get an assembly from to simplify this?
I tried a kit from New Port Engineering that provides just a new (12v) motor for 51-52's, and it was a complete failure and waste of a couple hundred bucks.
Is this the one you used?
I have the Newport and don't like it; the sweep is just a tad too much for the OEM arms, so I had to disconnect the passenger wiper arm for it to work. Told Newport about it but they are positive that their motor is correct. So I want to replace it.
I believe the one I have is the second one. The first one looks a lot like the New Port retrofit system.
I went ahead and purchased this one from Dennis Carpenter, they got them back in stock.
Took a few hours to install it. Took the seat out; I'm getting too old to cram myself over the pedals and between the seat and firewall. First, my cowl holes were a little too far apart, so I had to file the openings a little. Then the passenger side linkage rubbed as it stroked that way; I assume that my cowl was a little bit twisted, which twisted the linkage enough to hit itself. So I ground the 2 overlapping parts down a bit, then put it back together.
No hitting, nice and smooth. Installed the defrost vents and ducts; passenger side hit that now. Took the vent out and reset the angle of the steel tube assembled it, installed it. Then pulled it out to adjust it again.
Got that perfect, then tried to install the switch. And guess what...it was too long to clear the aftermarket gauge cluster. So I clipped the male connectors on the switch to about 1/8", drilled a hole through each one, and soldered leads to each. Checked the fit, got plenty of clearance, so I crimped male connectors to the leads, made the connections to the harness from the motor, and heat shrinked each connection. Glued a piece of rubber to the body of the gauge cluster just in case there was any contact and got it all installed.
Put my wipers on and tested it.
Put the seat in and started driving.
This unit runs quieter and wayyyy smoother than the Newport unit. And it was actually about the same price as the Newport unit. I would highly recommend the DC assembly to anyone.
Thanks for the input.
