F500 holmes wrecker
VIN help
Hello all and thanks for the add. I just purchased an old F500 with a holmes 480 wrecker bed. And looking for a good vin decoder. I've been working on it. The ol girl runs great! I was told that it was a special ordered truck. With a 5speed trans and a 428 industrial engine. But I thought these only came with a 330. Also I thought the 428 wasn't available in '72. Any help would be appreciated F50CRM43232 is the vin.
F50CRM43232
F50 = F500
C = 330 2V MD FT gas V8 (cast 360 crank, small distributor, some other FE items)
R = San Jose Assembly Plant.
M43232 = 1972 numerical series, August of 1971 production.
No chance it was a 428. Last 428 was 1970 in cars. What it has now??? Does it have a 4BBL carb? How many bolts in the exhaust manifolds--look for two in the center in addition to the two at each port.
The warraty plate will tell if it's a special order but won't tell you what that was all about other than if there are other items missing on the warranty plate that might be DSO items like transmission or axle or color.
F50CRM43232
F50 = F500
Warranty plate would be on the driver door, riveted to the door just below the latch. If the door was replaced, the plate may have been removed. Worst case is someone changes the door and leaves the old plate on there causing confusion as to VIN and equipment.
That engine appears to be an FE and therefore not the original engine.
The exhaust manifold does not have the two extra bolts for the center crossover. The intake isn't clear enough but does not appear to have the crossovers in the center.
How does this engine mount? It does appear to have the front mount as I don't see any side mounts, but check them anyway.
A 330MD to FE swap is pretty easy because the front cover has the bushing to fit the FE sized crank, and the flywheel is neutral and can bolt up to an FE, along with the bell. So an FE could mount right into the OEM mounts and look right at home.
But check the mounts and check the stroke. A wire down a plug hole at TDC and BDC will give you a measurement to compare against the 3.5" or 3.78" or 3.98" stroke found in the 352/390/410-428.
Only a teardown or cubic inch tester will tell more.
That engine shows some curious details such as the breather to the side of the carb hose (should be PCV to plate under carb), the rubber fuel line (fire risk), the custom fit and paint air cleaner, plumbing department heat hose connection, all standard for 50+ vehicles.
Ford definitely put 428's in industrial power units. Back when I was searching for a 428 for one of my Mustangs, there was a guy selling them on Ebay. He had collected these power units for years, and was parting them out. I bought a block and a crank from him. The block has stripes on the sides of the casting, which I have since learned makes them service replacement blocks for Mustangs, but standard issue for power units made a few years after they stopped putting them in Mustangs. I do find it unlikely that somebody could "special order" one in a truck, though. They would have had to have a special connection to get that done. Where is the picture of the data plate?
Chuck
Chuck
Chuck
Chuck
Chuck
Chuck
There should be a Ford Power Products information plate on one of the valve covers.
