'95 F250 5.8L oil coller discontinued part an looks like no aftermarket either
;so, while waiting on rear leaf spring bushings to arrive, I started looking at my slight coolant leak.
hand sized wet spot under front center behind radiator... drips off of center link from lower radiator hose. I cleaned up underneath and it appears to be a hairline crack in the plastic part of the lower hose or the hose bibs on the oil cooler are leaking. oil cooler also has oil gunk all over it.
I researched here and found that I might need to find an O-ring to go behind the cooler to stop oil leak but if its the original oil cooler its time to delete or replace it
Problem is, that its a discontinued part and I do not see any aftermarket one...
https://www.tascaparts.com/oem-parts...Y4LWdhcw%3D%3D
trying to determine if another year or model cooler will fit. ie. possibly a 2000 V10 Excursion? cooler looks the same but a smidge bigger??? both trucks use an FL820 filter.
any ideas? or somebody solved this issue?
I could delete my cooler and get a non oil cooler lower radiator hose and use an FL1A filter right at the block.Then later, find a remote mount air cooler and add oil cooling back in
thanks for any input or ideas
Mad_Max_F150
06-29-2014 04:21 PM
