Is it simply a matter of using 3-2WD running board drop brackets to raise the R.B.'s and fix some of the break over angle on a 4WD F-350? I mulched my factory 4WD brackets and R.B.'s. Powered, retracting R.B.'s would probably take it in the shorts where we like to go.
[QUOTE=}x2 stock f150 ones work. or stock raptor take off's. those are the same as tremor ones.[/QUOTE]
So, are you saying there is a difference between 2WD - F-150 and 4WD - F-150?
Can anyone post a pic of the 2WD F-150 stock running board?
Thanks.
jefe
5" wide take off F150 boards. They only have two brackets per side instead of the three the SD have and flex a little in the middle but I've had no issues in the almost five years I've owned the truck.
