Trailer Marker Light Wire No Power
About 2 months ago, I noticed that with any trailer I plug in there were no power to trailer running lights. With a new heavy duty bumper, the original 7pin and 4 pin factory installed plug will not work so I am changing to a new hard wired plug. In checking all wiring in the factory harness, the brown wire which is for running lights has no power. All others are fine.
I do not have a wiring diagram to see if the wire is spliced somewhere in the harness to connect the truck tail lights which work fine. Those wires are to small to carry a trailer marker light load so I though they may have spliced along the harness near the rear of the truck.
Does the brown wire go all the way to ??? and is it fused???
Need some help finding the issue.
2018 Ford F250 Super Duty
Thanks
Vic
Thanks
Vic
Fuse 99 on the 2018, I had almost the same problem. The fuse had continuity across it but I was only getting 3.7 volts. Replaced the fuse and all was good. If you are .looking at it from the passenger fender/front, it's the very back right fuse closest to the motor. 30 amp.
Did you unplug or plug in the 7 pin while the truck was running? If so, there's your culprit.
idsubgun
06-19-2013 08:07 PM
fordman19762003
Electrical Systems/Wiring
11-13-2012 11:42 AM
dangerranger10
1983 - 2012 Ranger & B-Series
07-03-2010 07:19 PM
hugger94
05-30-2009 10:12 PM
