Sponsored by: Real Truck
Plug/Trailer wiring need info ?
Old Dec 13, 2003 | 08:52 PM
zoomanmc's Avatar
zoomanmc
Have a little problem with the wiring on my 99 F250 4x4 SD.
The clearance lights went out on my trailer. I tested the plug and didn't get any power for the clearance lights, everything else works.sigs,brakes,elc brakes....
Iv'e gone under and check the wiring and the plugs..
what i've found is the trailler plug is good and the plugs are good but no power coming from the clearance light wire.
I trace the wires back and come to main wiring harness and still no power....
Also the clearance lights on the truck still work..
Does anyone no where those wires go and if there's maybe a fuse.
It seems the trailer plug has It's own sperate wires in the harness....
where does it go.........................
Any help would be great...................
Old Dec 13, 2003 | 09:34 PM
99f350sd's Avatar
99f350sd
The clearance lites are hooked to your park lights. Do you have park lights on the trailer that are working? If so then you have a trailer wiring problem not the truck.....
Old Dec 14, 2003 | 01:27 PM
zoomanmc's Avatar
zoomanmc
Jumped the clearance lights on the trailer with 12 volts and they worked...
The plug (not really the plug but the clearance power wire going to the plug coming from the main wire harness on the truck ) on the truck is the problem .I traced the wires back to the main harness and still no power...
Do those wire go under the dash or somewhere else?
And can I jump off the truck wires that goto the tail lights ?
Thanks for the help.........
Old Dec 14, 2003 | 02:16 PM
99f350sd's Avatar
99f350sd
JUMP EM
Old Dec 14, 2003 | 02:51 PM
cards8086's Avatar
cards8086
I had to change a fuse in the box under the hood.Cannot remember which one but it was yellow and had the type of fuse you can see the wire inside.Good luck
Old Dec 14, 2003 | 05:43 PM
zoomanmc's Avatar
zoomanmc
Cards8086 Thanks for the help ..
Look around and found the fuse box and check the yellow ones first and there it was .
Hook up to the trailer and everything works......
The plug is alittle loose so the lights flicker on big bumps..
Time for a new plug.............
Thanks to everyone who replied
Old Dec 14, 2003 | 06:16 PM
FortyFords's Avatar
FortyFords
That loose plug is whats causing the fuse to blow.
It creates a high resistance.
Just thought I'd add this also ,water getting into the plug doesn't help either.
you problably knew this already !
Rich
