Is it only to ovoid to spread overflow cooling liquid on the road or is there an other purpose ?
It keeps the coolant from deteriorating as quickly as with an "open" system, since it keeps the radiator completely full. Also reduces corrosion in the entire system.
That is, if the system is working correctly.
X2 not OEM at all, but if it is working like is should why remove it? Same for the window washer fluid reservoir, yea NOT OEM but it is works, roll with it.
Our systems won't suck back any coolant from an overflow tank. Unless you have a different radiator and cap. Years ago, I looked into this as I wanted the security of an OF tank. I learned that it just wasn't designed for it. Somebody correct me if I'm wrong and please provide proof.
