Dorman Fuel lines any good???
Has anyone used the Dorman fuel supply and return lines from the pump/return frame mounted to the engine supply?
Bad or good?
Dorman makes pretty good stuff and I honestly never had a single issue with any of their products, sometimes being life savers!
I will pay the extra for most stuff to stay factory, but these things seem awfully expensive for all they are...
Their headlight assemblies for our Tahoe are still airtight, no leaks or condensation after almost 2 years. Ebay ones in our old Tahoe were crap in less than 6 months..
Bad or good?
I didn't use dorman fuel lines but I did use the El cheapo fuel lines from amazon. I think they were like 35 bucks and they worked fine. Not sure on the seals that came with them although for the entirety of the time I had those seals on there they held fine but they just seem odd being as they are white and made of an unknown material but, they never did leak. When I put my new engine on the fuel lines were still sealed. But the parts truck I had had a set of fuel lines on it that were OEM and I cleaned them up and painted them while I was still driving my truck with the weak engine, so I would have a nice painted set of fuel lines to put on with the new engine. But at the time that I took them off I think I probably had them on for 6 months? Maybe longer I don't know. And they didn't leak a drop but if you want to be on the safe side just get some good seals to go with them but, they worked great for me and they were cheap. Actually I think I still have them sitting at the house if you wanted them you could have them.
I had bought a doorman valve cover gasket and built in harness which is an awesome design but the wires were peeling their outer shell exposing all the bare wire after only 1 year.
I think doorman parts are ok unless it's electrical. I think all of their cast stuff that was designed to fit in a certain spot that I bought did fit. They do have some very interesting stuff that has come in handy but, I will never again buy anything electrical. And things like sensors, or major engine gaskets, anything that's really difficult to change I'd rather not use dorman. That's just my thoughts on it. Nothing electrical and no rear main seal
So you paid more for Chinese parts than you could have paid for factory parts? https://www.riffraffdiesel.com/fuel-...ine-set-99-03/
that was a lot of work,
I would be inclined to just order up a full new harness.Swag Performance in TN
https://tinyurl.com/5eaem59t with California Emissions $250.00 new
no returns, be sure the correct item is ordered….
VIN# specific, do not order without contacting Swag
Swag Performance & Off-Road
4007 Highway 31 West
Cottontown, TN 37048
Phone: (615) 452-6003
https://swagperformanceparts.com/
READ!!!...wrong lines...its not price for me ever. Used Dorman repair ends on countless Fords and GM. Not a single leak or comeback.
Its price vs. actual performance... I think paying for everything up to this point proves it. And if you took 2 seconds to look at any of the pics, you would see the Sinister Diesel fuel bowl delete...why on earth would i even have a need for them. Do some reading first THEN reply....geeze
Opinions vs. Experience
Now I'd never use the UVCH from then...why? Experience...the wiring pulls away on the inside exposing bare wire. I have factory FORD on it now.
Diagnosing will be a cake walk so the time and effort easily outweighs the cost and function of a standard harness. I think when you see the end result you will understand. I will have EVERY wire available to me to check continuity and function within seconds...no probing, no unplugging...and no more 31 wire plug...most wires green and fail from some yoyo probing the wire...few take the time to at least silicone the small hole. And even then an oil contaminated wire will eventually release the bond. If you think these things have wiring, do some big trucks sometime...
Wiring is shielded, soldered ends, shrink tubed, friction taped, encased in ABS harness, friction taped again then braided encasement. No factory wire will outlive that.
I appreciate the input and I did think about it...trust me...I believe all of you will actually love the idea. My brain is trained to look 7 steps ahead. Just like the fuel lines, these are easy to get to and replace.
"If you don't have time to do it right, when will you have time to do it over?"
Stay tuned...
If they leak I will absolutely post about it. I was looking for someone that actually installed them on their ride and may have had issues....thats all
