Dorman Fuel lines any good???
Old May 10, 2024 | 10:15 AM
mikenamys's Avatar
mikenamys
Has anyone used the Dorman fuel supply and return lines from the pump/return frame mounted to the engine supply?
Bad or good?
Dorman makes pretty good stuff and I honestly never had a single issue with any of their products, sometimes being life savers!
I will pay the extra for most stuff to stay factory, but these things seem awfully expensive for all they are...
Their headlight assemblies for our Tahoe are still airtight, no leaks or condensation after almost 2 years. Ebay ones in our old Tahoe were crap in less than 6 months..
Old May 10, 2024 | 10:25 AM
John in OkieLand's Avatar
John in OkieLand
there is a lot of bad words with Dorman,
but I have used a lot of their parts w/o a complaint on any of them.
so far, no wiring harnesses for my 7.3L though
Old May 10, 2024 | 10:30 AM
Tpayne621's Avatar
Tpayne621
I think @Hyakkimaru used them. I rememeber him doing something with those fuel lines but can't remember exactly.
Old May 10, 2024 | 11:31 AM
Hyakkimaru's Avatar
Hyakkimaru
I didn't use dorman fuel lines but I did use the El cheapo fuel lines from amazon. I think they were like 35 bucks and they worked fine. Not sure on the seals that came with them although for the entirety of the time I had those seals on there they held fine but they just seem odd being as they are white and made of an unknown material but, they never did leak. When I put my new engine on the fuel lines were still sealed. But the parts truck I had had a set of fuel lines on it that were OEM and I cleaned them up and painted them while I was still driving my truck with the weak engine, so I would have a nice painted set of fuel lines to put on with the new engine. But at the time that I took them off I think I probably had them on for 6 months? Maybe longer I don't know. And they didn't leak a drop but if you want to be on the safe side just get some good seals to go with them but, they worked great for me and they were cheap. Actually I think I still have them sitting at the house if you wanted them you could have them.
I had bought a doorman valve cover gasket and built in harness which is an awesome design but the wires were peeling their outer shell exposing all the bare wire after only 1 year.
I think doorman parts are ok unless it's electrical. I think all of their cast stuff that was designed to fit in a certain spot that I bought did fit. They do have some very interesting stuff that has come in handy but, I will never again buy anything electrical. And things like sensors, or major engine gaskets, anything that's really difficult to change I'd rather not use dorman. That's just my thoughts on it. Nothing electrical and no rear main seal
Old May 14, 2024 | 07:41 AM
mikenamys's Avatar
mikenamys
Made my own wiring harness...
Old May 14, 2024 | 07:44 AM
mikenamys's Avatar
mikenamys
I went ahead and got the lines...got em at cost so $165
Old May 14, 2024 | 07:57 AM
liquidlounge's Avatar
liquidlounge
Originally Posted by mikenamys
Dorman makes pretty good stuff....
You may be the first person to have ever said that. Don't get that confused with finding a Doorman product that actually works and is OK to use - which is always big news!
Old May 14, 2024 | 10:02 AM
duck fan's Avatar
duck fan
Because racetruck
So you paid more for Chinese parts than you could have paid for factory parts? https://www.riffraffdiesel.com/fuel-...ine-set-99-03/
Old May 14, 2024 | 01:17 PM
John in OkieLand
that was a lot of work,
I would be inclined to just order up a full new harness.Swag Performance in TN
https://tinyurl.com/5eaem59t with California Emissions $250.00 new
no returns, be sure the correct item is ordered….
VIN# specific, do not order without contacting Swag
Swag Performance & Off-Road
4007 Highway 31 West
Cottontown, TN 37048
Phone: (615) 452-6003
https://swagperformanceparts.com/
Old May 15, 2024 | 08:34 AM
mikenamys's Avatar
mikenamys
READ!!!...wrong lines...its not price for me ever. Used Dorman repair ends on countless Fords and GM. Not a single leak or comeback.
Its price vs. actual performance... I think paying for everything up to this point proves it. And if you took 2 seconds to look at any of the pics, you would see the Sinister Diesel fuel bowl delete...why on earth would i even have a need for them. Do some reading first THEN reply....geeze
Opinions vs. Experience
Now I'd never use the UVCH from then...why? Experience...the wiring pulls away on the inside exposing bare wire. I have factory FORD on it now.
Old May 15, 2024 | 08:47 AM
mikenamys's Avatar
mikenamys
I am not running anything to the valley so the GP relay and wiring will no longer be where the wiring is at on the harness..not paying 500 bucks for harness prone to rubbing thru inside the harness. Swag performance harness is NOT factory ford...Chinese made...
Diagnosing will be a cake walk so the time and effort easily outweighs the cost and function of a standard harness. I think when you see the end result you will understand. I will have EVERY wire available to me to check continuity and function within seconds...no probing, no unplugging...and no more 31 wire plug...most wires green and fail from some yoyo probing the wire...few take the time to at least silicone the small hole. And even then an oil contaminated wire will eventually release the bond. If you think these things have wiring, do some big trucks sometime...
Wiring is shielded, soldered ends, shrink tubed, friction taped, encased in ABS harness, friction taped again then braided encasement. No factory wire will outlive that.
I appreciate the input and I did think about it...trust me...I believe all of you will actually love the idea. My brain is trained to look 7 steps ahead. Just like the fuel lines, these are easy to get to and replace.
"If you don't have time to do it right, when will you have time to do it over?"
Stay tuned...
Old May 15, 2024 | 08:57 AM
mikenamys's Avatar
mikenamys
Apparently no one has used them to even have a say other than people badmouthing them without ever using them. So I will be the guinea pig then...
If they leak I will absolutely post about it. I was looking for someone that actually installed them on their ride and may have had issues....thats all
Old May 15, 2024 | 10:09 AM
duck fan's Avatar
duck fan
Because racetruck
Are you okay? So I missed a detail. I've been wrong before, just ask my wife. No need to freak out. Good luck with your project.
Old May 15, 2024 | 07:16 PM
John in OkieLand
I was wrong once in my life,
but actually, I was mistaken then.
Old May 16, 2024 | 02:56 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Yup.
I know Peter, he's likely worked on more 7.3s than you've had orgasms.
Glad to learn from your new techniques but please remain civil.
