Why is this happening?
2015 F-250 CC 4X4 PSD 113,300 miles
I understand the mechanics that cause this, but I am wondering why it is suddenly A LOT worse. I have a ton of oil in my cold side pipe. Enough to cause some drips and to mist a little spray on the inside of the hood. A few years ago, Ford replaced the CCV box with the newer, non-serviceable, non filter box. I don't see any blow-by, and there are no other oil leaks indicating crank case pressure is building up. The pic of the pipe was taken today, after being wiped clean about a week ago. I also have some that is misting out past the boots. Any ideas?
You have a "boost leak", the oil is coming from either the CCV, or turbo seals most likely the CCV as there is not much you can do about oil in the intake with a CCV system, you can make it better several ways, but it will always be there. Fix the boost leak and you'll be good most likely.
Looks like several wraps of teflon tape and 5 minutes should do the trick on the sensor threads.
That is a Rudy's lit, so I'll see if I can order them.
So, what I am hearing is that amount of oil at the boots, and the side of the intercooler coated in oil, is normal for a stock truck? Seems like a lot to me, especially since it started to get bad about 8k miles ago.
Thanks for everyone's replies.
@speakerfritz how's your IAT sensor bung there? Any leaks like that at all?
did you recently try a new brand of oil…some oils foam more than others.assuming your not over filled.
Have you been driving with higher loads such as heavy towing? Can cause more blowby, therefore more crankcase vapors that end up in your intake via CCV.
Kayakn
05-02-2020 01:39 AM
LSO1123
03-20-2016 10:20 AM
