New find after oil change
Any guesses on the noise? I bought it recently did the oil, now it sounds absolutely horrible. Video for the
reference. It’s the in the front. I’m not sure what it’s called differential? Transfer case? More I learn more I feel really scammed with the purchase but what’s life without people lying
its a 5.8l v8 4x4
edit: here’s a link to the noise
https://imgur.com/a/r1okgyG
its a 5.8l v8 4x4
on
What did the old oil look like?
What weight oil did you put back in?
If there is a lot of sludge buildup in the motor(from not doing regular oil changes) then when you do it can knock sludge loose which then gets pulled into the oil pickup which can block it and that results in low oil pressure and knocking noises. Or it could be that the motor is just worn out and the OP had some really thick oil in it to make it quiet. Put a real oil presure gauge on the motor... the dash gauge is just an idiot light, if oil presure is zero at idle then you know.
ive seen a video where people use that Lucas oil and heavy stuff to sell it, haha guess I fell victim.
on
whoa did I **** up big time? I googled and did autozone they say even 5w-20 or I’m I inputting it wrong? Should I swap over to one of those??
What you kept zooming in on is the front differential. Nothing in that is moving while the truck is parked. The noise is from the engine. What year truck?
There was a Technical Service Bulletin (TSB) from Ford about using 5W-30 as the preferred weight but I don’t use anything lighter than 10W-30. This is from my owner’s manual.
Received 3,171 Likes
on
so obviously it would be wise to use something much thicker, but is that a bandaid fix? Should I definitely get it check out?
I figured unless I lock the hubs it doesn’t do anything I just didn’t know, like I said I came into this truck completely blind with no help so it’s tough trying to diagnose things. Maybe I’ll swap some heavier stuff into it today
1994 f150 v8 4x4
