New find after oil change
#31
Received 3,263 Likes
on
#32
im a mig welder but recently lost my job, I don’t know anything but this all just seems expensive with the tools I’ve been buying and will need, I don’t have anywhere to store an engine inside, my driveway is just about long enough for my truck but it’s sloped sideways big time so no jacks
i was looking for 2nd hand welders recently but not sure if any looked worth their pricing aside from basically new machines for almost retail, they don’t really break
i also have been to my local pick n pull those engines are gutted, or do you mean a different kind of junkyard? I didn’t think I could find one that cheap but I doubt I could do it by myself is kind of the problem, Its just me and my girl I don’t really have much help aside from YouTube
I hear you, you’d have to find a place to do it. Some places have a shop space you can rent for a weekend, or a friends garage, etc.
There’s a range of prices on car-part.com, $300-1,000. I bet if you were at a junkyard with cash in hand, they’d make a deal rather than let you walk away. I bought one, 30 day warranty, pulled and loaded on my trailer for $360 usd 2 or 3 yrs ago, and I live in no man’s land. No to your question, I mean just a regular junkyard, pick n pull, salvage yard, recyclers - who ever has one for sale. I doubt any do it anymore, but some yrs ago would help you swap it out right there, I think those days are long gone. But worth asking around.
As far as technical resources (how to) YouTube can be a help, lots here will help you through it, I wouldn’t worry about that part. Haynes manual probably has everything you need in it. Might make a fun project for you and your girl.
Might even find a backyard mechanic that can do it for you on weekends and evenings in his garage, and you helping. Try asking in your California FTE chapter. You never know, someone may know of a cheap engine and help you get it going again.
As above, if I were closer I’d help out too. Good luck with it.
The following users liked this post:
#33
Wading in here late in the game.
That noise sounds valve train related. It seems to be about 1/2 crank speed, and rises and falls with RPM.
The lighter oil didn't cause it.
A bit of a tear down might reveal it and it might be fixable.
But--can you park it until you get the job and money situation figured out?
OP is in CA, so an engine change will require things to be put back exactly as it sits so it will smog and not throw any flags for the smoggy.
No sense trying to do half fixes or shortcut it--better to sell it as a lame duck.
Good luck.
Good luck.
#34
Good luck.
Good luck.
Might be a dumb question but if I do take the engine out, it has to be stored inside if I open it up right?
#35
Really appreciate you guys offering the help. It makes me smile having people be so willing. It seems like she’s frozen until I get the ***** to open it up,and I source a welder to get that crack fixed.
I sourced some flat stock that I’m going to bend and cut to fit for the future.
one last thing if anyone might know but I’ll drill the ends of the crack, fill it, how big should the plate be to be safe? Is there a recommended way to repair and reinforce it
#36
Valve covers first. Check for anything funny.
Front cover next. See what is happening with the timing gears and chain, and maybe take a peek into the oil pan. If you have one of those inspection cameras you can see more.
Intake. That will expose the cam and lifters to a great degree.
You should cover and "seal" any open engine. Remove all coolant and debris.
You may find the issue or be on to full engine removal.
#37
I haven’t heard the video, so can not comment.
If it can be repaired without removing as suggested above, you can do it in your driveway. Get a tent, or tarp and rig up a cover above you. Just needs to be enough to keep the elements off. You can cover up the open engine itself with another smaller tarp and bungees for the night. Set up a cheap camping tent in front of the truck to work in if necessary. Even a garden shed to work in if you remove the engine.
As far as structural repairs, you’ll have to get access to it and see what it takes. From the look of it, it looks like the crack extends over the top of the cross member, I can’t see in your pic where it travels to. If it is the same as a 250, the cross member is welded to the frame as well as riveted.
It will be difficult to access the top of the cross member from inside the bottom of it, especially with the drop bracket in place.
Good luck with it, maybe you’ll get lucky with a bad timing chain or rocker etc.
#38
#39
on
#40
Not sure if it’s bad to revive posts but I’m looking for some more help, I ended up taking it to a shop for a run down. They said they removed the belt and the sound went away my engine sounds “great”, I didn’t know you could take the belt off and run it so that’s knowledge for next time.
anyways they called me and said it was my water pump, limped the truck back home, read the papers and noticed it said my air injection pump. So I called back, but this they time they doubled down on the air pump, so I was very confused because I googled the water pump on the phone with the mechanic and told them not to install since they wanted $900 for a part that was $70…
long story short I bought the stupid 300$ smog pump(thanks cali). Did not fix the sound.
my water pump is leaking already, should I just replace it anyways and see what happens?
#41
Pick up a mechanic stethoscope. They are not expensive. It should come with a long metal rod. Listen to each component as it is running. Just be very careful working around the belt driven accessories and fan, remember you can’t see the fan when the engine is running.
Ive had bad bearings go in an out of balance in the past, meaning the noise could be intermittent, or only at certain rpm. You might need a helper to run the throttle.
For all you know, the new air pump could be bad right out of the box. Diagnose the issue is before spending any more on it. Pictures and you tube video would be a lot more helpful.
#42
on
#43
Picked up a stethoscope, I poked everything I could reach and think of, couldn’t find the noise while it was quite loudly knocking, both the new smog pump and old water pump has a little whirring is all. Does that mean the shop was dumb and it’s internal? I poked what I thought was every pulley accessory, when I did my trip around the block I noticed it kicks in when uphill/load on the engine if it helps
#44
#45
I’ve read they recommend stone cold engine for belt off
