S363 Turbonator
Old Mar 29, 2023 | 02:31 PM
brokestroke's Avatar
brokestroke
S363 Turbonator
Finally took the plunge and ordered one of these units. This thread is dedicated to the install, performance and documentation of my experience with Turbonator VGT housing for a 73mm turbine.
Before ordering I went through all of the performance options available for the 7.3 (besides turbo). I was originally set on Injectors, hpop and fuel system to go with the T4 setup I currently have. The options available are great but I just didn't see the appeal to it all. Didn't want to mess with tuning, core charges, quality control etc. So I decided to leave everything "stock" and just add a Turbonator into the mix. I may change the HPOP in the future but that is more of a wear item.
The truck is relatively stock, it has a custom tune, FFD oil logs, T4 turbo mount, built transmission and 4.30 gears.
First off, the quality of this piece is outstanding! Packaging was superb and it basically comes with a contract that you agree upon when you remove it from the box.
Old Mar 29, 2023 | 02:53 PM
knottyrope's Avatar
knottyrope
clutch heim joint mod? jk
that looks purrdy
Old Mar 29, 2023 | 03:08 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Am I correct in remembering the Turbonator turbine output requires a different down pipe mating surface than the Borg Warner turbine?
Any other modifications to the T4 kit hard parts that you anticipate having to make?
Old Mar 29, 2023 | 03:19 PM
brokestroke
Yes, it requires an HX40 (holset turbo) downpipe flange. I might already have the parts on the shelf needed to fab one up, have to check. Also ordered a rebuild kit for my s363 from KC turbos. Besides that it should be 100% bolt-on.
Old Mar 29, 2023 | 04:06 PM
FordTruckNoob's Avatar
FordTruckNoob
Welcome to the club!! Did you feel your soul leaving your body when you signed that document like I did?
Old Mar 29, 2023 | 04:10 PM
FordTruckNoob
that looks purrdy
That is actually one of many running changes DPS made to the Turbonator before arriving at the current incarnation with mechanical-only actuation.
Old Mar 29, 2023 | 04:38 PM
brokestroke
Havent filled it out yet, dont want to forget!
Old Mar 29, 2023 | 05:47 PM
Tpayne621's Avatar
Tpayne621
What's this contract consist of? lol If you haven't signed it yet that means your safento say. 😂
Old Mar 29, 2023 | 06:08 PM
FordTruckNoob
Something something soul something something eternal damnation something something donuts…
Old Mar 29, 2023 | 07:42 PM
Wes444's Avatar
Wes444
Old Mar 29, 2023 | 08:48 PM
brokestroke
This was in the top of the box.
Anyways, here is a video on how to calibrate the actuator. The vanes are preset to the same location as in the video. I messaged them and asked what boost/ebp ratio I should target while tuning, they said 1:1.
Old Mar 29, 2023 | 09:33 PM
FordTruckNoob
I suggest opening the unison ring cavity and lubricating everything in there with tungsten disulfide dry lubricant while the surfaces are still relatively uncontaminated.
Old Mar 29, 2023 | 10:55 PM
Wes444's Avatar
Wes444
Interesting that they added that line in the contract about FTN
A snapped turbo shaft will always be considered abuse 🤔
Old Mar 30, 2023 | 07:15 AM
FordTruckNoob
It wouldn’t be the first time I caused legal repercussions.
Old Mar 30, 2023 | 09:24 AM
HKusp's Avatar
HKusp
Can you link to this exact set-up please? I would like to read about it. Thank you.
