Brake Light Issuse
Brake Light Issuse
Hello all. I have a 1979 F150
My brake lights aren't working. While doing a search on the topic I read in a thread that if the emergency flasher goes bad that can effect the brake lights, so I checked that but it seems to be just fine. The fuse doesn't look bad, and the hazard lights turn on so I'm sure it's not that. Couple other things I read that I haven't had a chance to get into yet, something about the cleaning up the four ground connections on each of the four corners of the truck, and updating the sockets. I'll clean up those grounds with a wire brush first thing. Any suggestion on the best type of socket to get? I bought new bulbs today and I recently replaced the brake switch that connects to the brake lever, it works just fine. Any other ideas of what to look for would be helpful. Thanks in advance.
You say you replaced the brake light switch and works fine?
So you have power going in and when pedal is pressed you have power out?
If so look at the turn signal switch as power out goes to it then out to left & right rear lights.
This is so when pedal is pressed and turn signal on the brake light does not work to that side.
Dave - - - -
Dave - - - -
Dave - - - -
Dave - - - -
If you have a test light, simply ground the pigtail and touch the probe to bare wire, both going into and out of the switch. Basically 12V current goes into the brake switch, and when the brakes are pressed it then goes into and out of the turn signal switch, thence to the rear to the actual sockets, through the brake light filaments, then out of the socket to ground. You should have juice to the switch all the time, and when the pedal is pressed both wires at the switch should be live. If so, great. The next easy step is checking the sockets, touching the probe to the little 'buttons' at the bottom of the socket - if you do not have juice there, your issue is somewhere between the pedal and rear. If you have juice at the socket, make sure the socket is actually grounding with your meter (sometimes the socket looks good but the ground connection is bad) and clean up the screw grounding point near the sockets. You can use the multimeter at every step I mentioned instead of the test light.
To check out back I would unplug the wire to the switch and use wire to jump it out so you can check out back.
I have a bunch of wires with clips just for this type of testing.
Dave - - - -
Originally Posted by RustyTank
Also, the sockets look really old. Would be worth it to replace them even if they're not the problem.
If it ain't broke don't fix it. But if they're old don't be surprised if they break soon (or 40yrs from now you never know) and you have to fix it.
So fix it now or fix it later. You got the time and money to spare fixing working parts go ahead, trying to save your pennies, just wait till it breaks.
IMO they are easy enough to get to that id wait till they break. <- again assuming like you said that they are not your problem
Yes and no lol.
Well I cleaned up the ground screw and all the contact points, still now power to the sockets. What's my next move?
Understood. For now I'll wait to replace them until I need to.
Will you please be more specific with me about what plug you're talking about?
I know of the plug that the brake pedal switch plugs into, that plug has two wires that then go into the wiring harness behind the gauges console.
