Pondering
Pondering
Lots of discussion on tires, pressures and capacities as of late. And that got me thinking back to when I ordered the truck in my signature. I ordered “heavy duty service suspension”, 3.55 axle, and other options that set it with a 11,300 lb GVWR. Which made it a good SRW tow vehicle for our fifth wheel (which scales at 12,200 lbs). When I go back and look at the offering materials from when I ordered my truck I now see that the only difference between a 11,300 lb GVWR rating and a 11,500 lb GVWR rating (all other options being the same) seems to be the tires. I ordered mine with LT275/65R18 tires that have a 3,415 lb rating at 80 psi. The other 18” tire option available then was LT275/70R18 tires that have a 3,640 lb rating at 80 psi, which seems to move the GVWR to 11,500 lbs.
So, all other options being equal on a 2015 F-350 SRW truck are tires the only difference between these GVWR ratings?
Received 6,860 Likes
on
The 2015 Specifications Brochure might be informative:
https://madocumentupload.marketingas...8bc83&v5=False
HTH,
Jim / crewzer
HTH,
Jim / crewzer
on
on
We like to think that the tree huggers and pot heads are limited to Denver and Boulder. If it wasn't for those two cities, this would be a great state. My EV has never had flowers anywhere on it!
