1970 460 pistons
1970 460 pistons
hey all still new to posting, I have picked up a 1970 Lincoln 460 for my 77 f-250 truck. It has D0VE-A heads. Just tore the motor down to the short block and found the pistons are eaten up from detonation. I’d like to keep this block and heads but I need to find lower compression pistons so I can manage pump gas any suggestions for brand and compression ration to shoot for? Also not sure what pistons to run for valve clearance, this isn’t necessary low budget but I don’t have loads of funds to dump at it.
In that case I'd try to stay around 9 or 9.5 to 1. 10 to 1 would work if your cam bleeds enough . and of course there are lots of factors at play which could help or hurt these figures.
now we're not talking stock smogger pistons anymore. so you need to decide just how much power you want and what you want to spend. you don't need forged pistons for your application most likely, good cast ones or hyperutectics would do just fine. just start looking around you should find plenty of options for a 460.
If you don't mind a few extra bucks for a roller cam I highly recommend it. I can give you the contact info on the guy I use if you'd like who custom specs me a grind for only a couple bucks more than an off the shelf grind. he can do flat tappet cams too if you'd rather. it would be done by Comp or Voodoo.
Then what intake? carb ? headers ? you have lots of decisions to make but it all starts with your compression ratio.
I’ve heard lots of mixed opinions on intakes. Either a preformer intake non rpm or a victor jr. I’ve got a fresh 600cfm edelbrock that runs anazing, I know that’s the stock size for this motor, I have a guy who said he would give me his 650avs ones he gets his new avs2, prolly no headers yet, I know I’m gonna kick myself cause I’ll loose power but for the price I can afford manifolds are gonna last longer and bolt up the the brand new exhaust the truck currently has on it. What cam would you suggest for manifolds? Cause that’s gonna be my choking point
Stock manifolds are fine. stock intake is fine too if you're not looking for high RPM performance.
The cam you need depends on many factors, find the pistons you want and determine the exact compression ratio, what heads, your gearing and such then chose a cam.
A roller cam will have a different profile than a flat tappet so that's another factor. but if you're going with a flat tappet off the shelf cam I'd be looking at something like a Comp 258 from the sounds of what you want.
Don't throw them away they're worth decent money. early closed chamber heads for 385 series engines are harder to find than you think.
If you've done some looking and can't find what you need you may be in a situation with limited options. buy a set of custom pistons or have a set of forged pistons dished. or sell or trade your heads and get some later larger CC ones.
I've run into this often. since originality isn't an issue I might opt for some later open chamber heads and keep it simple.
no name
03-11-2003 08:18 PM
85351ho
07-17-2002 02:10 AM
