Help needed for battery tray/cover on a 48 coe
Hi all.
I have a 1948 coe in the UK that I have acquired it has been taken apart Most of the things I can work out where they go. I'm a but stuck on the battery fittings etc that fit on the step. Could someone please help me with pictures so I could compare
Ta Dave
Ta Dave
You might want to check out this COE build thread: https://www.ford-trucks.com/forums/1...uck-build.html
Here is what I have on my "50. Hopefully, with enough interest, there will be in the works soon, a fiberglass repop for the battery cover and right side running board. This battery cover will be used as the mold. The spring latches are available at hardware stores.
Battery placement on running board
Inside battery cover
Outside battery cover
The other member I'll be working with also works in carbon fiber so the structures may be done that way instead of FRP. I forgot to bring my battery cover home last week so it'll be another week before we get started. Strong possibility there will be steel inlays at high stress points. We are both experienced in FRP from the marine industry.
green49f1
10-11-2014 11:37 PM
Super Steve
05-28-2008 04:30 PM
