Simple oil leak question for a simple mechanic
Hello- recently I was looking down in the engine bay and noticed a small oil leak coming from the passenger side near the back of the engine. I cleaned it up and after pressing and feeling noticed some oil seeping out of the cover (see pics below). I am a very amateur mechanic, more determined then skilled, so could someone let me know the correct way to fix the leak- i'm guessing a new gasket? Any guidance would be appreciated as well! Thanks- Spencer
after pressing on the cover I noticed some oil coming out of where the cover meets the engine.
seepage when pressed!
97in-lbs is the torque spec, tighten them correctly. Helps immensely to remove the few 8mm screws that hold the vacuum reservoir to the HVAC box.
https://smile.amazon.com/GearWrench-...ch+flex+socket
Gearwrench 80311 is a great tool set. Also very useful for uppipe fasteners and to R&R the turbocharger. Seriously, just buy the set. Having the correct tool for the job makes work fast.
Harbor freight has the same tools... I use them once in a blue moon so I opted to go cheap,
https://www.harborfreight.com/7-pc-3...set-67908.html
Alright so last weekend I opened up the hood and loosened then re tightened all of the bolts holding the valve cover on, but still couldn’t get it to stop leaking. I feel like there is something preventing it from being tightened down all the way, a previous reply said something about stud nuts that need to be removed? I guess next move would be to replace the gasket?
There is one on the drivers side rear, not sure about the passenger side. Best way to tell is to feel back there and if you feel threads at the top there should be a nut on it. Remove the nut, carefully. Using a deep socket you can now tighten the stud which is part of the existing threaded assembly. Kinda like a thread - nut - thread, all one unit. This combination usually secures some sort of cable clamp but my truck didn't have one attached so I eliminated putting the extra nut on top. Hope that makes some sense.
Only studs I recall on the passenger side are on the dipstick. If you fart around with that, I would at least replace that blue o-ring for the metal pipe into the pan. Driver side has some at the back by the firewall, a few on the top for the CCV pipe, and I think one more for the engine harness.
Your cover can easily be warped. Take it inside and set on a flat surface to verify. Also, remove the vacuum reservoir from the evap box. Two or three 8mm head screws, makes life much easier.
If pulling a cover, do a quick glow plug test with a test light. I would consider pulling one to verify it is a ZD-11 unit. Yes, repairs on these snowball out of control...but you are dealing with a 25 year old truck.
https://www.thedieselstop.com/faq/94...an/stjmain.htm
Go to ENGINE. DIESEL. ROCKER ARM COVER.
