Radiator support Mounts
Im trying to replace the radiator support on my 1996 f150,4.9. It was really bad shape. The problem I'm having today is trying to cut the old radiator support bushings or mount free from the frame. I cut the nut off at the top, where I was able to remove a square shaped washer, a shim, a thick spacer and another washer, but I can not get the bolt out of the frame support. The head of the bolt and washer is on the bottom side and a washer with a hexagon shape opening in the middle that slides over what looks like a hexagon bolt (?). Should I cut between the hexagon washer and the frame mount. I'm not sure if that is the answer either.
Thanks Sandy,
I tried to send to a response earlier, it didn't go.
I have tired that, I started spraying PB blasted on wednesday last, then tried the Mac Tool impact today, but it doesn't want any part of it. It just hammers. I would have thought it would have snapped by now, but no.
So Im back to either cutting out with a saw-zall, cutting under the washer. Die grinder, by segmented the washer on top and peeing it off then replacing the OEM washer with a standard washer. ( do I need to use the OEM washer?) or trying to drill it out.
Any recommendations?
Not sure what I need to do here. I know I just put the impact back on it and it has been on there so much I have started to round the head of the bolt so it's not going to be useable to get it out. It would seem that is the head was off the bolt it should be free to pull out. I don't see what else could hold it tight. I would love to see the gem bolt to really understand how this is intended to work.
Body Mounts - Gary's Garagemahal (the Bullnose bible)
Here's an illustration of how everything goes together.
Well, It can be cut out. Below is a picture of the bottom side of the heavy washer that captures the radiator support mounts. The round circle in the middle is the bolt, the inside hexes the heavy washer, the outside hex is another washer:
[img]blob:https://www.ford-trucks.com/2f1f9d35-624a-49c5-9a89-20b2b593ee42[/img]
Looking at the top side of the heavy hex washer that captures the radiator support mount;
[img]blob:https://www.ford-trucks.com/0411ba2f-637c-4ec7-b10d-fdbd6e7eeb6a[/img]
The bottom radiator support mount, below the frame support.
[img]blob:https://www.ford-trucks.com/aac4cc8a-3aa9-4da2-a6ce-6a7d4d833ece[/img]
The frame support. I cut the bolt/assembly as close to the frame support as I could. I didn't realize there was yet another washer next to the frame support, which made it a little difficult.
[img]blob:https://www.ford-trucks.com/b361b182-e234-4214-97c7-065371cf77a7[/img]
I used a 9" long reciprocating 18TP1 blade to cut. My truck has a lot more washers than what is defined. I have a total of 5 on each side, one is .50 thick.
The radiator support was really bad, I'm putting the new radiator support back with urethane mounts.
Thanks for everyone's help. Sandy...A special thanks to you for gather information for me.
Glad you got it out. In seeing that diagram I could tell it could be cut. It's been a long time since I was in there so I wasn't positive about cutting. I could not duplicate those bolts since they are so long and threaded to the top. I ordered them from Bronco graveyard and they come as a kit with bushings, bolts etc. I just looked at that diagram again. Read the part on the left about motion control about the distance between the support and bushing mount. Maybe that is why you have so many spacers. I'm going to check my distance tomorrow. I think I only had two per side but I put all mine back in. Sandy
applebaggins
34
11-10-2017 06:39 AM
tom1979
02-08-2007 06:31 PM
svooom
10-22-2004 06:11 PM
ceetwarrior
10-24-2003 09:23 PM
