water pump., not leaking but not moving water correctly...
restrictive heater hose
restrictive heater core
dashboard control doors... allowing outside cold air into heater system.
dashboard heater control themselves
Where did you get the new thermostat? I spent two winters chasing no heat only to discover not all thermostats are equal. Finally swapped yet another thermostat but this time OEM. 10 minutes later I had heat again.
the big "C" and not Chevy... had a recall of ten's of thousands of defective thermostats....
the first time it opened,, the bridge bent and caused the valve to remain open.. till replaced..
