stiff steering?
Old 12-11-2018, 10:21 PM
thunderbird1986's Avatar
thunderbird1986
thunderbird1986 is offline
stiff steering?
hi every one. I have not been on here in a while. just bought a 08 F150 Fx4. the steering is pretty stiff to turn at a stand still or on the road while driving. is this steering supposed to be stiff because it is a FX4? It has no whining or binding. it does have power steering fluid in it though. I do not know if that is the problem as the manual says mercon V. its almost like manual steering but easier. is this because of the off road package? is their anything to check? for example. power steering pressure switch
thanks
Old 12-11-2018, 10:23 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
Well these year trucks are known for weak pumps and failed steering gear spool valves. I would bet money it's a bad steering gear.
Old 12-12-2018, 11:04 AM
stephen.osborne1's Avatar
stephen.osborne1
stephen.osborne1 is offline
See if you can find another, similar model at a dealership to test drive and compare. I'd expect a pump going bad to make some noise, and since it is easier than manual steering, I've gotta think the pump is at least working somewhat. x2 on the steering gear...
Old 12-12-2018, 06:17 PM
Bent6's Avatar
Bent6
Bent6 is offline
The U-joint in the steering shaft is known to lock up. You can buy a Dorman shaft, but it's likely the steering wheel will be crooked after installing it.
Old 12-24-2018, 10:10 PM
thunderbird1986
ok, a little stupid here. I checked the air pressure in the tires. they were pretty low. they did not look low to the eye but they were. put the correct amount of air in the tires and it steers totally different now. its not like steering a car with steering assist or anything but it became way, way easier. it almost feels like driving a car with (sport) steering.
thunderbird1986
thanks for the suggestions. it still may be the other problems also.
JMyers0901
03-26-2013 11:22 AM
Caleb H
01-02-2012 10:50 PM
Methodical_1
02-06-2009 07:22 PM
nexis1
06-08-2001 01:01 PM
Quick Reply: stiff steering?
