The hose to nowhere? should this be connected to something?
There should be two hoses coming from the coffee can. It is not the charcoal filter. The charcoal filter is located nearer the radiator and has two round caps on top of it. Can you take a picture of the coffee can hose you are talking about? Sandy
Edit If you don't have cruise control you may only have one hose and it should go to the vacuum tree if I am remembering correctly.
Here's what it ought to look like. Should be a vacuum hose running up to the purge solenoid (your picture). From there it goes to the intake. As Sandy said that "coffee can" is an entirely different animal - a vacuum reservoir. However, I thought in '96 they weren't the rust prone metal cans, but a plastic bean-shaped thing. At least, that's whats on mine!
Follow the hose with the plastic corrugated cover back towards the black widget, Vapor Management Valve (VMV). I suspect someone has cut that line.
That is part of the air injection system. It has no interaction with the evap system you are inquiring about. It is not what a previous post was referring to anyway.
That cut hose is probably what connects to the hose on the right side of the charcoal canister.
thanks, that hose from the charcoal filter is what was missing back at the VMV. i inserted the hard plastic tube back in the rubber with hose with a hose clamp now to keep it sealed and in place. not sure how i missed that hard plastic tube before, but i was probably looking for a larger rubber hose.
what about that big open hose on the fender? should there be something there?
I assume this is a photo from your 1996 F150? Seems odd since the 1996 V8 Bronco did not have a CANP solenoid, it was replaced with a Vapor Management Valve (VMV) located in the same spot as the first photo from the OP. My manual shows the V8 F150 did as well. Perhaps the 6 cylinder model had a mid-year change?
Javi1
6.7L Power Stroke Diesel
22
03-21-2015 09:44 AM
mamabear13
07-23-2008 10:43 PM
