What do I have here?
I'm Mel from Northern CA. This relic as been sitting on the ranch here for a few years. Used to butcher cows (see attached crane and winch). It's a '62 FWD V8. Not sure what I should do with it. If I decide to sell it, I'm not sure how to properly describe it. Is it worth salvaging? What would you do with it?
It's either an F100 (5 lug wheels) or an F250 (8 lug wheels) 4WD with an 8' Flareside pickup bed.
It's as rough as a cob, but has value, does it have a pink slip?
Suggest removing the crane/winch and don't mention in the ad it was used to butcher steers. Some people are squeamish, then there are the vegans.
Woof, that one is rough. There's value but it's disappearing with every raindrop. The bedsides look taller than normal from your picture. There was a thread hear not long ago where someone was reviewing the different bed types out there on these, so that might be good to look up - lots of good discussion.
Na - you could point out it was ONLY used on vegans. That's called marketing.
I was told that it ran by my father before he passed, but it took a few weeks to figure out some minor issues with the engine - the gas tank rotted at the bottom seam. The only running problem I have now is the gas pedal is a bit sticky so it get's stuck revving high sometimes and you have to pump it.
I would think the winch was added by the dealer or even afterwards but appears to be period correct and I think adds to the value of the truck. Keep it on there for sure. Cool truck.
