Changing Rear End Fluid - Should I?
Could be a used water truck... If so, you definitely need to replace the rear diff and front diff (if it has one).
I had a 2006 4x4 (bought new) and the rear diff had a metal tag on it that said something like: Synthetic Do not replace, Do not inspect.
But that's if all is well and no suspected of anything.
Many water (flood) vehicles are coming out of hurricane states. Do be careful... The truck could have been sitting in water up to the bumper for days or weeks.
This forum has someone who wrote in and found water inside his rear diff.
Like Chuck said.....DO IT.
It is cheap and easy. I do all my cars every two years (Subaru AWD) and just did my F-350 dually two weeks ago, before the cold temps rolled in. I also replace brake fluid in the same weekend. Two jobs that I do every two years as I drive 105 miles for work five days per week.
— Dave
— Dave
Check the below for the correct rear diff oil....
6.7L Power Stroke Maintenance Schedule
Service ProcedureService Interval(s)
Replace engine oil & oil filter
10,000 miles or as indicated by the instrument cluster message center
(Intelligent Oil Life Monitor system will adjust interval to driving conditions)
Replace fuel filter
22,500 miles or as indicated by the instrument cluster message center
15,000 hours/6 months/600 hours under severe duty conditions
Replace engine air filter
45,000 miles or as necessary
(inspect at oil change intervals)
Flush engine cooling system
Initial flush at 105,000 miles/6 years followed by 45,000 miles/3 year subsequent service intervals
60,000 miles/2,400 hour initial flush under severe duty conditions
Replace automatic transmission fluid & filter
150,000 miles
Replace transfer case fluid
150,000 miles under normal conditions
60,000 miles under severe duty conditions
Replace front differential fluid (4x4)
50,000 miles under severe duty conditions
Replace rear differential fluid
100,000 miles under normal conditions
6.7L Power Stroke Service Part Numbers
Note - Select part numbers may not be applicable to 2017 model year trucks.Engine air filterPre-filter
Motorcraft FA-1909 (Ford BC3Z-9601-D, replaces FA-1907)
Air filter
Motorcraft FA-1902 (Ford BC3Z-9601-A)
Engine oil filter
Motorcraft FL-2051S (Ford BC3Z-6731-B)
Engine oil fill cap
Motorcraft EC-786 (Ford EC3Z-6766-A, Motorcraft EC-780)
Fuel filter set
2011 - 2016
Motorcraft FD-4615 (Ford BC3Z-9N184-B)
2017
Motorcraft FG-1117
Glow plug[1]
2011 - 2012
(12/1/2012 cutoff date)
Motorcraft ZD-17 (Ford BC3Z-12A342-B)
2012 - 2016
Motorcraft ZD-18 (Ford BC3Z-12A342-C)
Thermostat
Motorcraft RT-1231 (Ford BC3Z-8575-D)
Cam sensor
Motorcraft DU-92 (Ford BC3Z-12K073-A)
Crank sensor
Motorcraft DY-1148 (Ford BC3Z-6C315-A)
Automatic transmission filter
(TorqShift 6R140, 6 spd)
Motorcraft FT-187 (Ford BC3Z-7A098-B)
6.7L Power Stroke Oil/Fluid Specs & Capacities
Oil & Fluid Specs
Engine oil10W-30
Acceptable viscosity in ambient temps > 0° F
(Preferred for normal usage)
5W-40
Acceptable viscosity in ambient temps > -20° F
(Trucks using biodiesel should use 15W-40 or 5W-40)
(Preferred if truck falls under "Severe Duty" service schedule)
15W-40
Acceptable viscosity in ambient temps > 20° F
0W-30/0W-40
Acceptable viscosity in all ambient temperatures
(Recommended in extremely cold conditions only)
Engine coolant
Motorcraft Orange Engine Coolant, VC-3DIL-B
(50/50 coolant-distilled water mixture if using concentrated fluid)
Automatic transmission fluid
Motorcraft MERCON LV automatic transmission fluid (ATF)
Transfer case fluid
2011 - 2016
Motorcraft XL-12 transfer case fluid
2017
Front differential fluid
SAE 80W-90 gear oil
Rear differential fluid[2]
Sterling 10.50"
(F-250, SRW F-350)
2011 - 2016
SAE 75W-140 full synthetic gear oil
2017
SAE 75W-85 full synthetic hypoid gear oil
Dana 80
(DRW F-350)
SAE 75W-90 full synthetic gear oil
Dana S110/S130
(F-450, F-550)
Dana M275
Dana M300
Oil & Fluid Capacities
Fluid capacities are nominal - always fill to proper level on dipstick or to fill plug level as applicable.All measurements in U.S. quarts ("qts") and/or pints ("pts"), NOT Imperial.
Engine oil capacity
13 qts w/ filter
Engine Cooling system capacity[3]
29 - 35 qts, varies by model year (7.25 - 8.75 gallons)
DEF Tank Capacity
2011 - 2016 pickup
5 gallons
2017 pickup
7.4 gallons
2011 - 2016 chassis cab
6 gallons
2017 chassis cab
7.2 gallons
Automatic transmission fluid capacity
17.4 to 18.5 qts (approximate dry fill capacity)
Transfer case fluid capacity
2.0 qts, 1.9 liters
Front differential oil capacity[4]
2.9 qts, 5.8 pts, 2.8 liters
Rear differential fluid capacity[4]
Sterling 10.50"
3.5 qts, 6.9 pts, 3.3 liters
Dana 80
4.25 qts, 8.5 pts, 4.0 liters
Dana S110/S130
7 qts, 14.0 pts, 6.6 liters
Dana M275
3.8 qts, 7.6 pts
Dana M300
4.5 qts, 9 pts
[1] Verify correct glow plug for application. Engines built before 12/1/2012 require ZD-17 glow plugs, while later engines require ZD-18 glow plugs. ZD-17 glow plugs are 91 mm long, while the later ZD-18 glow plugs are 96 mm long; only use the correct glow plug for your engine.
[2] Limited slip differentials may require a supplemental friction modifier - use Motorcraft XL-3)
[3] Nominal primary engine cooling circuit capacity. Because the 6.7L Power Stroke is equipped with an air-to-water charge air cooler (intercooler), it features a second cooling circuit.
[4] Nominal differential oil capacity. Always fill axle to fill plug level and do not rely on the oil capacity as the actual refill capacity. Use provided figures as a reference to obtain the necessary fluid quantity only.
