Drops dead on acceleration when cold
With 892504x4's help, we figured out the fuel pressure was spot on, and not the cause of the trouble. Couple things happened while he was there that were a little strange.
Didn't start right up. That is pretty weird because it's been rock solid on starting.
Died twice while idling. That is also pretty weird and I'd never seen this behavior before.
I will re-classify this problem as a "stumble" on acceleration when cold. The engine speed drops, sometimes quite dramatically, on acceleration when cold. Now that we've ruled out fuel pressure, air temp sensor, coolant temp sensor, and main brain what's the next thing to check? 892504x4 suggested PIP or AFM? Another odd thing was when creating a vacuum leak it ran better when cold.
on
When did you replace the 2 sensors and EECM? after the "stumbling hesitation on acceleration"?
and the the result of changing those components was; it now "dies"?
Have you compared the Resistance of the New and Old sensors?
Have you checked the supply voltage to the sensors?
With the first cycle of the ignition fuel pressure went to 33 and held when we hit the no start the pressure was at 40psi and holding.
Here is what the info I have used to test the ICM.
https://easyautodiagnostics.com/ford...module-tests-1
I can loan you my led test light on Thursday.
