Lee, Welcome to FTE! To answer your question, Yes it is an easy, bolt in swap if you have all the correct parts. If you have the half bell on the V8 it will bolt right in in place of the six. You will need to move the radiator back approximately 2" to the V8 position. Since you need to move the radiator back, you will need the V8 air deflectors in front of the radiator and in the hood. The battery tray is on the drivers side on the six and the passenger side on the V8. The throttle arm on the firewall is different on a V8 than on your six also. The starter solenoid will need to be moved to the passenger side firewall, the holes are already in place. If you have the parts or have a V8 parts truck, F1-F6, it is an easy swap.
Mark
