Amount of coolant in 239 block?
I am putting a good used radiator in my 54. I've had 6 cylinder radiator in it since 1999. The inlet is on the passenger side on a 6 cylinder radiator. So last year I bought a real good 8 cylinder radiator for $100.
I just re-read the thread Ross started earlier this fall about good and bad antifreezes for our old trucks. Basically it says don't use antifreeze that has OAT in it.
I am not sure what kind of antifreeze is in the truck now, so I am going to flush my block. The shop manual says the radiator holds 22 quart of coolant. That's 5.5 gal. What does the block hold? Will I have enough if I buy 3 gal of concentrated antifreeze and 3 gal of distilled water? Or will I need more?
Thanks!
Thanks!
Correct. I've never gotten the full 22 qts in mine, even with a fresh engine and empty heater, more like 20.
I keep a couple empty anti-freeze jugs laying around so whenever I need to fill a radiator, I can pre-mix my own coolant 50-50 before adding it to the vehicle. That way I don't have to guess or wonder if I got the right mix in the engine. And if I have some left over, it sits on the shelf just fine until such time as I need to top something off, still maintaining the recommended mix.
Thanks guys. I bought 2 gallons of NAPA antifreeze concentrate good for Ford vehicles 1998 and older and 2 gallons of distilled water. That will give me 16 quart. I going to buy one gallon of NAPA premixed and that will give me a total of 20 gallons. If I need more I'll buy another gallon of premix later.
Thanks for the help.
Parlusk
08-11-2016 10:33 PM
mozzles
08-23-2014 10:06 PM
rustyranger390
28
08-20-2011 01:39 PM
00 Nav
01-02-2010 03:25 AM
OrangeJuice
01-21-2008 10:28 PM
