7.3 Running terrible when cold
I have a 2002 F250 7.3. When cold (morning start up or sits a while) the truck runs like ****!! It idles rough, when I take off it starts going (very very sluggish) then the more I step on the pedal the less RPM's I get, I take my foot off the pedal and ease into it, it starts going (very sluggish) then again RPM's come down, Step on it again and same thing, then sometimes it'll stall and it's very hard to start back up, also when im on the pedal and it don't really move, I see white smoke out of the exhaust. Then once I get going, it'll prematurely shift into OD and shake till the RPM's finally come up. Once it warms up, it runs perfect, no issues at all. The colder it is the worse it is. I'n the summer it does it but not nearly as bad, it's sluggish then clears up.
Sounds like you might have a glow plug issue. If you have a relay there are some easy ways to test it. I've seen the threads but never paid attention as I have a Glow Plug Control Module.
My truck did not like to run when it was cold. I replaced my injectors and glow plugs in the past year and now it's not happy but runs decent when it's cold. I can't say for sure since I put new injectors in there (although my old ones were running fine when I took them out) but I did replace all my glow plugs (originals with 306K miles on them) and it starts and runs better from the get go now.
Hopefully someone will be along with more help. In the meantime there are plenty of hard start threads that might have some help.
Thank You!!
I agree with Brian, GP’s maybe GPR and finally depending on your mileage maybe your injectors are tired. I had the same issue, replaced GP’s, GPR, it helped marginally. Finally changed the injectors, turned out 6 of the 8 were original with 353K Miles. The truck now starts -10 without issues. Try plugging it in for 5 hours and see if that helps...
It sounds like injectors to me. If you want to read a saga, you can read my cold start thread right here. I had 155K miles on my truck and was very good about sending in used oil analysis and maintenance in general back then. I didn't even want to THINK it was injectors, but that's what it turned out to be. Once I changed them, THEN the real saga started, but that is a whole 'nother story.
320kmiles
01-19-2014 09:35 PM
cabloom300
02-14-2013 10:24 PM
